DA brakes on a REX problems??
What exactly is the problem everyone says it messes with geometry but what causes that, a mount? Some say it fine when the car is lowered, correct?? is this a simple bolt on of the knuckles for a 91 Si?
i think the problem your talking about is the positive camber, so when you lower the car (which causes negative camber) it goes back to zero, or close to it. i had this problem when i put EK hubs on my car
I had no problem. When I first put them on without aligning the car my turning radius was HUGE, but once aligned and toe was corrected, it went back to normal.
vshavoc
Nov 7, 2008 12:17 PM
