2.25" or 2.5" exhaust piping
Old Dec 5, 2005 | 05:54 PM
broketuner-Sol_Si's Avatar
Default 2.25" or 2.5" exhaust piping
As some of you know I plan on doing a mild NA engine build on my B16A in the near future. Is my current 2.25" setup going to be suficient or would I get quite a bit more power out of a 2.5" piping? I'm just trying to do every thing right the first time so I don't need to spend more $ correcting mistakes.
Old Dec 5, 2005 | 07:45 PM
808_si's Avatar
what is your setup?
Old Dec 5, 2005 | 07:53 PM
NathanMorris's Avatar
Default Re: (808_si)
2.5" in my expereince with NA applications is ideal for maximum power from a street car. I have not seen any negative effects of using it, and the benefits of 2.5" become more and more apparent as engine output increases. 2.25" is prolly going to come within a whp or two though, so it's up to you.
3" is something I'd like to experiment a little with. Though, I'm probably just going to go with an electronic cutout for my particular project that's wired to either an rpm acitvated switch (if i find that power is lost in lower revs), or to a switch that can just be turned on or off at the track.
Nathan
Old Dec 5, 2005 | 07:55 PM
xEnderx's Avatar
Default Re: (92Lx)
I'd presonally go with 2.5. Matter of fact....thats what I did.
Old Dec 5, 2005 | 10:07 PM
WhoisDan's Avatar
Default Re: 2.25" or 2.5" exhaust piping (broketuner-egb16a)
I went from 2.36" to 2.5".
Old Dec 5, 2005 | 10:17 PM
sleepycivichb's Avatar
3" thermal but I baught it for my built 2.0, currently running stock interal 2.0 now and seems to work just fine. I'd go with 2.5" with your motor.
Old Dec 5, 2005 | 10:32 PM
Ek-CoolGuy's Avatar
Default Re: (sleepycivichb)
I running a 60mm (2.36") ex and I wish I went 2.5. It's hella quiet though, even with a test pipe, which I am actually happy about.
Old Dec 5, 2005 | 10:54 PM
As far as the setup I plan on running, something similar to or actual CTR components. I will also have Intake mani(already bought, need to install), headers(need to buy) and a 64.5mm overbore TB(coming when I install the mani.) and I already have exedy lightweight flywheel/clutch, Intake, exhaust and basic tune-up. I plan on keeping it a DD, and hopefully still being legit on smog.
s13hero
Nov 24, 2010 05:21 AM
91crxturbo
May 13, 2007 06:32 PM
-Championship-
21
Feb 13, 2007 04:44 PM
Rory Breaker
Dec 11, 2002 10:43 AM
InTeGrA B18b1
Jun 10, 2002 11:13 PM
