question i need answered
Old Dec 5, 2005 | 11:20 AM
em Dot's Avatar
POOPCheeks
Default question i need answered
so im swapping a b18a into a crx wednesday. i got new integra axles, hasport shift linkage and shifter and complete wire harness to make the job smoother. my problem is that i've heard people using motor mounts off of an integra and when i do a search for motor mounts for a crx, i hear that you need after market mounts. i searched everywhere for an answer . i checked jdmshit.com and they said you need the mount kit, but they might be saying that just to sell their stuff. please any help is appreciated since my motor is going in wednesday.
Old Dec 5, 2005 | 11:22 AM
Autoworks's Avatar
Default Re: question i need answered (em Dot)
You do need the Bseries notor mount kit. Hasport , AZ Race, whoever.
Old Dec 5, 2005 | 11:25 AM
ZCHF's Avatar
Default Re: question i need answered (Autoworks)
yup, need a mount kit like any b series.
you can get one on ebay for pretty cheap
Old Dec 5, 2005 | 11:27 AM
em Dot's Avatar
POOPCheeks
Default Re: question i need answered (ZCHF)
thanks guys....also i read you need the throttle cable off of an integra too?
Old Dec 5, 2005 | 11:29 AM
Autoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by em Dot &raquo;</TD></TR><TR><TD CLASS="quote">thanks guys....also i read you need the throttle cable off of an integra too?</TD></TR></TABLE>
you dont "need" one, you can make a cable bracket extension and use your old cable
Old Dec 5, 2005 | 11:32 AM
em Dot's Avatar
POOPCheeks
i had a problem like that when doin a turbo setup with the edelbrock manifold and the throttle stayed open. is the stock cable shorter than integra ones?
Old Dec 5, 2005 | 11:45 AM
Autoworks's Avatar
https://honda-tech.com/zerothread?id=1326198
If you look right under the "EED" you'll see I just made a piece that moved my OE bracket over about 2"
Old Dec 5, 2005 | 12:06 PM
em Dot's Avatar
POOPCheeks
i kind see what you did. cool that helps a lot . thanks
si90rex
Jun 20, 2007 04:14 AM
BACKintheDA
Mar 19, 2004 06:30 AM
floyddan7
Aug 15, 2003 04:56 AM
eddiecut
10
Jul 17, 2003 09:29 PM
UNDER PRESSURE
May 23, 2003 05:01 PM
