EG door panel removal w/manual windows
Old Dec 5, 2005 | 11:19 AM
90gs's Avatar
Default EG door panel removal w/manual windows?
I have it all ready to come off besides the manual window thing that you wind.. how do i take off the manual window thing that you wind so i can remove the inner door panel?
some gay thieves broke into my car and trashed the outer handle, now i'm getting inside there to see whats wrong...
Old Dec 5, 2005 | 11:22 AM
littleredcivic's Avatar
taking off the window crank is easy and should have been the first thing you did. inside is a little spring clip that is wire and shaped like a U. use a small screwdriver or a mini hook to pull it out. when you take it out, it might fly...so be careful, to see it, just push the door panel away from the center of the crank. there is also a specific tool for it, but there is no need to buy it for a honda.
Old Dec 5, 2005 | 11:54 AM
90gs's Avatar
Default Re: (littleredcivic)
gotcha, thanks
Old Dec 5, 2005 | 11:57 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (90gs)
Id use a hook-pick tool to grab it. Also, when you go to put it back on, put the clip on the window handle before putting it back on.
Old Dec 5, 2005 | 03:58 PM
DB1_559's Avatar
Default Re: EG door panel removal w/manual windows? (90gs)
needle nose
jalexcar
Jul 12, 2008 09:21 AM
vlc92189
Oct 8, 2006 10:17 AM
AnclyT
Jul 18, 2005 12:01 AM
flatblk
Jul 12, 2004 10:30 AM
wm5holla
Mar 23, 2003 04:18 PM
