VTEC won't engage...need some helpgin
Old Dec 5, 2005 | 07:58 AM
d16EK's Avatar
Default VTEC won't engage...need some helpgin
I've been wondering for a while if my VTEC was engaging because I never could hear it or really feel it so I wired up a VTEC light yesterday and it never lit up when I went driving. Only flashes when the key turns. I spliced it up to the green wire with a yellow stripe on it. It's a 00' EX with a d16y8. If my VTEC solenoid were to be really dirty, could it stop it from engaging? I really want VTEC, my 1/4 mile time is a lot worse than it should be and I need all the help I can get.
Old Dec 5, 2005 | 07:59 AM
1 point 6's Avatar
Down Since Day 1
Community Builder
Community Influencer
Default Re: VTEC won't engage...need some helpgin (d16EK)
check the power to the solenoid?
Old Dec 5, 2005 | 08:02 AM
d16EK's Avatar
Default Re: VTEC won't engage...need some helpgin (1 point 6)
I checked the wire to the VTEC solenoid and as far as I can see, everything is plugged in. I'll check it again though. By power wire you mean the green wire, right? There's only one.
Old Dec 5, 2005 | 08:04 AM
Hondaciv95VX's Avatar
For this being a Vtec thread, its actually a decent one.
least you tried to see foryourself what was happening.
Old Dec 5, 2005 | 08:12 AM
1 point 6's Avatar
Down Since Day 1
Community Builder
Default Re: VTEC won't engage...need some helpgin (Hondaciv95VX)
i meant checking the power by using a test light to see if the solenoid itself is getting power.
d16EK's Avatar
lol thanks...but like I said before, if the solenoid is really dirty, could that stop VTEC from engaging?
Old Dec 5, 2005 | 08:33 AM
1 point 6's Avatar
Down Since Day 1
Community Builder
if the inside is dirty, but some grime on the outside shouldnt stop it unless its stopping it from being properly grounded.
also, check your oil level. low oil level will also stop it from engaging.
Old Dec 5, 2005 | 08:42 AM
d16EK's Avatar
I just changed my oil and I don't have any leaks but I'll check it just to make sure...I guess the only thing to do is to check it with a test light. What else can stop VTEC from engaging?
Old Dec 5, 2005 | 08:44 AM
93turbo16's Avatar
speed senors, oil pressure, coolant temp, load, rpm
So I would say take the solenoid off and clean the screen of the VTP switch.
Old Dec 5, 2005 | 09:29 AM
d16EK's Avatar
Default Re: (93turbo16)
alright, Im going to do that here in a little while. Thanks a lot for the help so far.
blacktibby07
14
Feb 8, 2011 08:48 PM
AnAccordIsForever
Jun 3, 2008 03:27 PM
a1320honda
May 19, 2004 05:53 PM
5 Liter Eater
Jul 16, 2001 09:57 AM
