Service intervals
Old Dec 5, 2005 | 01:35 AM
budget-boy's Avatar
Default Service intervals
Hi,
I have a Uk spec CRX VTi (B16a) 1994 standard except for AEM CAI.
Could you tell me how often you should clean/replace the CAI filter? If it is cleanable how do you do it and what do you use?
How often do you change plugs/leads? My OEM have not been changed (or plugs) in the 2 years I have had it. Is is a case of "if it ain't broke don't fix it" or should I change em out?
Is it worth paying out for geniune Honda plugs/leads or is there a cheaper/better alternative?
Thanks
Dave
(Robin Hood country)
Old Dec 5, 2005 | 05:07 AM
AutoXer's Avatar
Default Re: Service intervals (budget-boy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by budget-boy &raquo;</TD></TR><TR><TD CLASS="quote"> AEM CAI.
Clean it when it's dirty using the K&N recharger kit. Usually around 30 - 50K depending on your driving conditions.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by budget-boy &raquo;</TD></TR><TR><TD CLASS="quote">How often do you change plugs/leads? My OEM have not been changed (or plugs) in the 2 years I have had it.
Sparkplugs should be changed every 30K. Plug wires should be changed when they are damaged, rubber starts to crack etc. I wouldn't use anything but OEM when replacing them.
fryman
Aug 29, 2009 11:01 PM
mehheh1029
Jul 31, 2006 07:37 AM
ncitrdude
Dec 9, 2001 11:15 AM
MacLeanQuinn
Sep 7, 2001 07:39 PM
