Do these axles look right?
I am helping my friend swap a B16 into his 90 Si CRX. I did the swap on my 90 DX that was stolen so it should be a piece of cake. I went to get the axles today at advance suto parts and said I need axles for a 93 integra without abs. They asked me for the model I said it doesnt matter. Was I wrong there? I think he pressed the GS model. These look different than the ones I got for mine from pepboys. Are they going to work alright?
Pep Boys, Auto Zone and Napa all use the same axles on all 90-93 DAs, the only Diff at all is if it comes with the ABS ring or not. I had F*&KED up axle issues with my swap in my '90 CRX Si and had to do all kinds of reasearch I even found that Auto zone and Napa used the same part numbers but on opposite axles!!?? That caused problems as well. I ended up measuring the axles from tip to tip (with the inner joint pressed all the way in) to make sure everything was cool., I think the factory measurement is "23 5/16 inches (not sure on the fraction part but they are 23inches for sure). As long as you do not have any bad control arms or other bad suspension parts then the Axles should work fine.
1337 Si
Sep 9, 2011 04:28 PM
