WHat Axles?
Old Dec 27, 2006 | 08:55 PM
Lethalb18c1's Avatar
Default WHat Axles?
Im looking to put a b16a2 (civic Si 99-00) in my 90 crx. what axles do i use? does it even matter as far as hydro or cable tranny in which axles to use? anywho let me know. Thank you
-Kyle
Old Dec 28, 2006 | 02:36 PM
EnjoyTheRideDC2's Avatar
Default Re: WHat Axles? (No_PassWorD)
You'll pretty much need a set of axles that mate with the tranny you choose to run. So if you're using the B16a2 Hydro Trans, you'll need a set of B series Hydro swap axles that fit your car. I believe the ones from a non abs DA integra would work??
Old Dec 28, 2006 | 11:37 PM
GetawayInMoscow's Avatar
Default Re: WHat Axles? (EnjoyTheRideDC2)
DA integra axles.
It doesn't matter if it has ABS or not, ABS axles just have a ring on them and are more expensive..
Old Dec 30, 2006 | 10:20 PM
boostedblkef's Avatar
Default Re: WHat Axles? (GetawayInMoscow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GetawayInMoscow &raquo;</TD></TR><TR><TD CLASS="quote">DA integra axles.
It doesn't matter if it has ABS or not, ABS axles just have a ring on them and are more expensive..</TD></TR></TABLE>
xlasianizelx
Mar 3, 2008 10:10 AM
NsX_CrX
Feb 5, 2007 07:50 AM
17
Oct 1, 2006 06:40 AM
b18c inside
May 4, 2005 06:38 AM
94si94cx
Oct 23, 2002 05:16 AM
