Heat not working out of no were
Old Dec 4, 2005 | 07:05 PM
sayd430's Avatar
Default Heat not working out of no were
97 Ex Cp, My heat was working one day then the next its cold as hell out and my heat dont work and im driving around with my fingers falling off my poor hands. I checked my underhood fuses , along with my fuse panel next to my cluch all fuses are good. Checked my radiator fluid and its not the fluid. I dont think its my heater core because there are no leaks but if anyone has any solutions to this problem let me know cause im FREEZING MAn
Old Dec 4, 2005 | 07:42 PM
civicracer59's Avatar
Default Re: Heat not working out of no were (sayd430)
Is the thermostat working? Is the engine temp going to normal or is it running cold all the time?
Old Dec 5, 2005 | 10:01 AM
sayd430's Avatar
Default Re: Heat not working out of no were (civicracer59)
The Engine Temperature Is the same but there is no heat
Old Dec 5, 2005 | 10:06 AM
_gurusan_'s Avatar
Is it blowing air at all?
Old Dec 5, 2005 | 10:56 AM
sayd430's Avatar
Default Re: Heat not working out of no were (_gurusan_)
Yeah its blowing air
Old Dec 5, 2005 | 11:06 AM
JDM-EJ1's Avatar
It sounds like it is your heater core, if the car heats up normally but no air is blown out of it.
What you might also check is, where the cable connects to the core (the thing that makes it change from hot/cold), check to see if that came disconneceted. It's located under the glove box on the passenger side. Look for a steel cable that is wrapped in black plastic, if it's not hooked onto anything that's the problem.
Old Dec 5, 2005 | 11:09 AM
Ricey McRicerton's Avatar
Default Re: Heat not working out of no were (JDM-EJ1)
I agree with the heater core. It sucks to replace them, so good luck.
Old Dec 7, 2005 | 02:46 PM
sayd430's Avatar
Default Re: Heat not working out of no were (Ricey McRicerton)
it turns out it was my temperature control valve was disconected from my dash
cornsnake19
Nov 28, 2017 09:11 PM
maznkid
Oct 21, 2011 05:44 PM
Ludester
Dec 3, 2002 03:50 PM
Infinity_Racer
Oct 17, 2002 09:37 AM
