Integra brakes in civic
I have integra cables in there at the moment and the mounting locations don't match up plus they are too long... I've tried ordering CTR cables from honda and they cant get them, there mechanic also said that the Si cables would be too long.
Has anyone else out there got a 96 + hatch with rear disks? if so what cables are you using???
Just a thought but have you tried using the 92-95 Si hatch e-brake cable. I knwo that the 92-95 civic si rear brakes and the integra rear brakes are the same size. And they also bolt up identically. So you might want to try that cable. Since it is about the same length as the 96-2000 hatches.
if only I read that half an hour ago
I checked with honda and the 96+ dx's, hatback and coup have the same cables so I ordered 99 Si ones, hope they fit
Ive got integra pb cables on my 96 hatch too. they work fine.
If you have problems, you can pry the brackets loose from the cables and move them around. But I didn't even have to do that to mine.
Short Round
Apr 5, 2010 09:27 PM
jus_spooln_wicha
May 14, 2007 12:40 AM
**DOHC HaTcH**
Mar 21, 2007 12:48 PM
Derfology
Feb 16, 2006 05:47 PM
