Integra or Si Rear Disc brakes
Someone locally is selling some si rear disc brakes without the ebrake cable for 150.
Can i use my existing e brake cable from my 2000 ex?
is there a difference between the si and the integra rear disc brakes?
thanks in advance.
thanks in advance.
Re: Integra or Si Rear Disc brakes (**DOHC HaTcH**)
there is a differance between the rear disc ebrake cable and on that is for drum brakes. I don't know if there is one between thoughs cars. check magestic honda get the part number and cross it to the integra see if they are the same
I forgot more about hondas then you will ever know....
Location: hop,skip, and a jump from the city,, new friggin york, USA
1 Post
the only difference will be that the ek brake cables will be longer then the integra units.
All rear discs are essentially the same... You need a ebrake cable from a EM1 for a perfect fit. All of this info can be found in the brake swap thread.
https://honda-tech.com/zerothread?id=1811368
Cool Cool Island Breezes. BOY-EE
Re: Integra or Si Rear Disc brakes (Chim Chim)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chim Chim »</TD></TR><TR><TD CLASS="quote">All rear discs are essentially the same... You need a ebrake cable from a EM1 for a perfect fit. All of this info can be found in the brake swap thread.
https://honda-tech.com/zerothread?id=1811368</TD></TR></TABLE>
I shoehorned in GSR cables on my 99 hatchbox when i did a 5 lug because i allready possessed said cables. I Had to bend/omit brackets, and almost completely extend the ebrake screw adjuster. But they fit and worked fine. The 99-00 Si cables will work much nicer with no shoe horning needed.
x2
x2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chim Chim »</TD></TR><TR><TD CLASS="quote">That's why I said to use EM1 cables for a "perfect fit". </TD></TR></TABLE>
yeah i think i meant to quote something else.
trip-doh
12
01-19-2008 10:19 AM
tekstyle
12-10-2007 01:40 AM
JLEK
17
06-11-2007 09:58 PM
