mini me help??
i am trying to do a mini me swap into my 1990 civic standard and i dont know which head to use. i have a d15b1 and some people told me to use d16y8 head but some said that the z6 will fit. please help
Modified by highrev1987 at 1:13 PM 12/4/2005
Modified by highrev1987 at 1:14 PM 12/4/2005
the only major difference in doing a mini me as of which head to use is the dizzy bolt patterns are different....I guess z6 head flows better in stock form but the y8 has a better combustion chamber area
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gnar kill »</TD></TR><TR><TD CLASS="quote">if you are going to stay bod 0....but please do it right and convert to obd 1</TD></TR></TABLE>
I ran a mini-me for a couple years with a chipped A6 ecu..worked just fine.
obd-0 if you are just gonna drive it, obd-1 if you plan on "tuning" it, IMO.
With the Y8 head you'll need an adjustable cam gear as the cam timing is 1/2 tooth off with that head (I'm not sure about the Z6 one).
a friend of mine told me not to do the z6 due to the head not fitting right. i just want a head i could install and wire, for obd1 and drive around reliably, if anyone can throw any more info in it'd be great.
also if you have an si or dx 5spd trans, i wtb
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d357r0y »</TD></TR><TR><TD CLASS="quote">
With the Y8 head you'll need an adjustable cam gear as the cam timing is 1/2 tooth off with that head (I'm not sure about the Z6 one).</TD></TR></TABLE>
As long as you use a 1.5 bottom, you will need to use an adjustable cam gear with either head
SPOON_BeIgHtEeNsEe
May 1, 2008 12:46 PM
mike93eh
Jul 20, 2005 02:39 PM
