Brake Swap on 96-00 Hatch
Old Mar 14, 2002 | 08:43 AM
Pho Real's Avatar
Default Brake Swap on 96-00 Hatch
Which is the best way to go GSR or Si?
Can I use my stock brake lines?
Do I need to change the Master C and/or the P Valve?
(Does anyone know where to buy 5 lug conversions ?)
Thanks
Old Mar 14, 2002 | 08:54 AM
DragII's Avatar
25 Year Member
Default Re: Brake Swap on 96-00 Hatch (VTEXTC HB)
they are identical....
no need for prop valve, and MC, but they are a nice upgrade
Old Mar 14, 2002 | 09:25 AM
BakedCookies's Avatar
ED2 is right they are identical, I have GSR all around with endless pads and slotted rotors, stock MC and prop valve, and my car stops on a friggin dime...
Old Mar 14, 2002 | 12:54 PM
Pho Real's Avatar
Default Re: Brake Swap on 96-00 Hatch (BakedCookies)
Cool - Does anyone know who has 5 lug conversions ?
Old Mar 14, 2002 | 01:14 PM
CheezeFrog's Avatar
Yeah, the thieves who stole my R.
Hey, so are the Integra LS brakes the same as the GS-R brakes? I just bought the rear LCA's & brakes from an LS. But for the front I heard I'd have to go with Si suspension/brake pieces because the Si spindle is shorter than the GS-R's, so I'd run into *positive* camber problems with the GS-R spindles unless I slammed the car, in which case I'd get near 0 camber. Good for dragging, but I want to be able run a little bit of negative camber for road racing possibly.
So should I hold out for some Si front suspension pieces? Or should I just go and get some front end Integra pieces. And do I need GS-R's or can I just use LS parts? TIA!
Old Mar 23, 2002 | 03:04 AM
HondaIntegraLS's Avatar
Default Re: Brake Swap on 96-00 Hatch (CheezeFrog)
I am also curious about this front swap. I was also wondering if instead of using the SI or Integra front spindle, can you just use one from an EX with abs since it is the same caliper and rotor as the Integra? I will probably try it out and let you guys know.
Old Mar 23, 2002 | 04:40 AM
VWkila's Avatar
Default Re: Brake Swap on 96-00 Hatch (EJ6 Dx)
Is GSR brakes same as rest of the Integras, except Type R?
[Modified by idgeek, 1:40 PM 3/23/2002]
Old Mar 23, 2002 | 05:06 AM
rainmanEK's Avatar
big strong guy
Default Re: Brake Swap on 96-00 Hatch (VWkila)
they are the same, i have gsr brake swap on my ek i love it! no mc or prop valve, could not imagine any better! only prob i had really was fitment of parking brake lines, i guess not really ment for my ek!
Old Mar 23, 2002 | 10:31 AM
Trey's Avatar
25 Year Member
Default Re: Brake Swap on 96-00 Hatch (rainmanEK)
The Si would be the better choice ONLY because of the rear emergency brake cables being the correct length.
Both will work finr though......
iiPancho
Apr 19, 2009 09:30 AM
19992civichatch
Sep 2, 2007 09:55 AM
kpop
Feb 7, 2007 12:32 AM
bboylito
Nov 11, 2004 10:19 AM
slut
Oct 29, 2003 12:57 PM
