Legacy LA2060 and Sony Xplod LS122P5 amp help!
Old Dec 3, 2005 | 08:21 PM
import810's Avatar
Default Legacy LA2060 and Sony Xplod LS122P5 amp help!
I have this amp http://www.audio-warehouse.com...l.asp
and two of these subs Sony Xplod LS122P5
I want to buy an amp installation kit but do not know what to buy. My amp is 2000w but from all the amp kits I saw at best buy they were only good up to 1500w. http://www.bestbuy.com/site/ol...76667
I am a total newb at audio and I need to kknow what to get to hook this all up. Do I need 8gauge 4 gauge 2gauge or what? Also what fuses will I need?
Old Dec 3, 2005 | 11:35 PM
import810's Avatar
Default Re: Legacy LA2060 and Sony Xplod LS122P5 amp help! (import810)
bmup I know some1 knows this
Old Dec 4, 2005 | 06:36 AM
fcm's Avatar
fcm
Old Fart
2000W
Tell me this, what size is the fuse/s in the amp?
I have looked and T can't find a the specs for that amp, but I would be very surprised if the 2000W rating is anything but a peak rating, [WSBL] let me know what size the fuse is or if you have a home page for Legacy Audio. 94
Old Dec 4, 2005 | 09:57 AM
import810's Avatar
Default Re: Legacy LA2060 and Sony Xplod LS122P5 amp help! (fcm)
hmm will this help http://www.legacycaraudio.com/...A2060
and on the amp there are 2 fuses that say 30
Old Dec 4, 2005 | 10:01 AM
92ehatch's Avatar
2000w would probably be the peak power on that amp.
i would say athat a 1500 watt wiring kit would be just fine.
Old Dec 4, 2005 | 10:10 AM
import810's Avatar
Default Re: Legacy LA2060 and Sony Xplod LS122P5 amp help! (93egsedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egsedan &raquo;</TD></TR><TR><TD CLASS="quote">2000w would probably be the peak power on that amp.
i would say athat a 1500 watt wiring kit would be just fine.</TD></TR></TABLE>
did u see the link I jus posted above? i think its 1200
Old Dec 4, 2005 | 01:50 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by import810 &raquo;</TD></TR><TR><TD CLASS="quote">hmm will this help http://www.legacycaraudio.com/...A2060
and on the amp there are 2 fuses that say 30</TD></TR></TABLE> Yes, the spec sheet rates the amp at 250W rms x 2 into a 4 ohm load so about 500W rms bridged into mono into a 4 ohm load http://www.legacycaraudio.com/...0.pdf [page 17] a 4ga wire kit will be more then enough. 94
Old Dec 4, 2005 | 02:43 PM
import810's Avatar
that manual is for a totally different amp? how big of a fuse should I run? 40amp?
Modified by import810 at 3:59 PM 12/4/2005
Old Dec 4, 2005 | 03:39 PM
fcm's Avatar
fcm
Old Fart
First link is for the LA2060 amp, the second link is for the same amp, the link I gave you is from your second link, at bottom of page "Item Manual LA2060 Click"
and yes the amp that it shows is the LA560, but if you scroll down to page 17 like I said you will find the spec sheet and it includes the LA2060.
Do not change the fuses in the amp, you can damage the amp, the reason I asked for the fuse size is if you don't have a spec sheet the size of the fuse will tell you how much power the amp is capable of making, 2 30A fuses is 60A, the amp is not capable of making 2000W rms, take my word for it, you need a hell of a lot more then 60A to make 2000W rms, so what you have is a peak rating, and again the 4 ga amp kit will work just fine. 94
Old Dec 4, 2005 | 05:29 PM
import810's Avatar
ok ill get a 4ga kit but jus wondering what does the 2000 refer 2?
Old Dec 5, 2005 | 01:22 PM
import810's Avatar
bmp
Old Dec 6, 2005 | 11:55 AM
fcm's Avatar
fcm
Old Fart
The 2000W on the amp and the specs they give refers to "peak" output power, it's the total max power the amp will make both ch. driven.
All amp specs will give you a number of watt ratings "RMS" per. ch. into into differant impedance's, [loads] 1ohm, 2ohm, 4ohm they may also give you that at differant voltages 12.5V to 14.5V, they will also give them to you in "peak" ratings, also into differant loads, and at differant volts.
Some manufacturers will take the total peak rating at the lowest load the amp is stable at the highest volts and stick that on there amp.
That's how you get an amp that is a 250W x 2 into a 4ohm load, presto chango, into a 2000W amp. It's called fudging the numbers. 94
Old Dec 6, 2005 | 01:47 PM
import810's Avatar
ahh i get it.. ( wow audio companies are ******* liars..... well kinda jus tricky)
Dub C
Audio / Security / Video
Feb 7, 2006 07:15 PM
96H22aLUDE
Jun 28, 2005 02:48 PM
shorty0o29
Mar 26, 2003 05:04 PM
beastgsr
May 28, 2002 12:10 AM
