4 Ohm DVC or 2 Ohm DVC
Old Mar 25, 2003 | 09:58 PM
shorty0o29's Avatar
Default 4 Ohm DVC or 2 Ohm DVC
I'm am going to get two 12" or 15" alpine type-r's and i dunno if i should get the dual 4 Ohm coils or dual 2 ohm coils what do you people think?
Old Mar 25, 2003 | 10:20 PM
JOMO
Guest
Posts: n/a
Default Re: 4 Ohm DVC or 2 Ohm DVC (shorty0o29)
*id like to take this opputunity to ask a stupid question, what the hell are ohm's and what do they mean to me? i see 4 ohm on my subs, have no idea about my amp settings and stuff...
ill buy some new subs soon, what difference do the ohms make?*
Old Mar 25, 2003 | 11:35 PM
vteg's Avatar
New User
Default Re: 4 Ohm DVC or 2 Ohm DVC (JOMO)
shorty, what amp do you have? This will determine what your buy.
jomo, read the first 10 sections here http://www.eatel.net/~amptech/elecdisc/caraudio.htm
As ohms decrease the current needed by your amp increases. If you run your amp at too low of a load(ohms) you get overheating, clipping, or amp failure. If you are lucky it will just cut off or blow a fuse. It is important to match your subs to your amps. You can put as many subs on one amp as you want just as long as the load is right.
Old Mar 26, 2003 | 12:03 AM
JOMO
Guest
Posts: n/a
Default Re: 4 Ohm DVC or 2 Ohm DVC (vteg)
ive tried to read stuff on that site but im too dumb, my heat hurts after a while and i need to get high
that did it for me, thanks! but how will i know what ohm my amp is running at?(did that even make sense?
Old Mar 26, 2003 | 08:59 AM
shorty0o29's Avatar
I dont have an amp yet first i am going to pick out my subs and pick an amp around that probably an alpine MRD-M500
Old Mar 26, 2003 | 09:47 AM
nOOber's Avatar
"did that even make sense? "
No.
the power output of your amp will say something like:
2 channels X 50 watts at 4 ohms
1 channel X 100 watts at 2 ohms
the impedance (ohms) your amp runs at depends on what the impedance load you show it ( this is your subs and how they are wired)
think of it this way:
more current = less resistance (ohms)
more resistance = less current
higher impedance is also higher fidelity, which is why you see home stereo gear at either 8 or 16 ohms. In a car where power is at a premium, SQ (sound quality) is sacrificed for higher current (and therefore less resistance).
hope that helps
Old Mar 26, 2003 | 05:04 PM
GSteg's Avatar
Default Re: 4 Ohm DVC or 2 Ohm DVC (nOOber)
this is where i disagree. the impedence does not affect SQ in any audible way. no matter if its 1ohm or 8ohm. if the speaker is recieving the same signal and same power, there will be no audible difference. will there be measurable THD differences between 1ohm and 8 ohm? sure. is it audible? not a chance.
under 1% is inaudible with test tones. i sometimes wonder how people hear the THD with music.
most amps nowadays that are 1 ohm stable will have a THD of under 2% at that impedence, which is still pretty much inaudible with music. so if 1 ohm has an inaudible THD rating, how is 8 or 16 ohm going to sound any "cleaner".
car audio and home audio are basically the same. what changes is the environmental surroundings.
Dub C
Audio / Security / Video
Feb 7, 2006 07:15 PM
Orpheus1985
Jul 21, 2005 07:15 AM
c mak
Oct 30, 2004 12:12 PM
Mr. Choi
Apr 19, 2004 10:06 PM
Ludeboi
11
May 26, 2003 09:57 PM
