I need someone to check their EG for me...
Old Dec 3, 2005 | 04:51 PM
transpar_nt's Avatar
Default I need someone to check their EG for me...
I'm in the middle of a swap right now and would greatly appreciate it if someone could check something for me in the engine bay of their EG. I don't even know what its called, but is a 4" horizontal cylinder on the back of the intake manifold. It has 2 vacuum tubes on it and 1 round 2 wire electrical plug. Could you tell me what colors the wires are on the plug?
Old Dec 3, 2005 | 04:59 PM
theif101's Avatar
Default Re: I need someone to check their EG for me... (transpar_nt)
green and,,,,,,,,,,,,,,,,,,,,,,, black with a yellow stripe
Old Dec 3, 2005 | 05:01 PM
damnraz's Avatar
it's called the IACV, idle air control valve, has two hoses connected at the bottom of the unit w/ a plug for the switch
Old Dec 3, 2005 | 05:02 PM
Default Re: I need someone to check their EG for me... (damnraz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by damnraz &raquo;</TD></TR><TR><TD CLASS="quote">it's called the IACV, idle air control unit, has two hoses connected at the bottom of the unit w/ a plug for the switch</TD></TR></TABLE>
Damn, so that's what the IACV is.
Green and black/yellow you say? Thankyou both!
Old Dec 3, 2005 | 05:11 PM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by transpar_nt &raquo;</TD></TR><TR><TD CLASS="quote">Damn, so that's what the IACV is.
No worries, I was lost on it at first too.
Old Dec 3, 2005 | 05:14 PM
Okay, I've got the wiring harness all connected and everything is ready to go except for one plug. It is a round, grey connector identical to the one that plugs into the IACV, except the wires are red, and yellow with a black stripe. It is directly under the intake manifold, but I can't for the life of me find any more open plugs!! (EG's harness onto a b18b1.) I looked back on the d15 but can't find a place for it there either which doesn't make any sense because I just took it off of there an hour ago.
Old Dec 3, 2005 | 05:57 PM
Brodie Bruce's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by transpar_nt &raquo;</TD></TR><TR><TD CLASS="quote">Okay, I've got the wiring harness all connected and everything is ready to go except for one plug. It is a round, grey connector identical to the one that plugs into the IACV, except the wires are red, and yellow with a black stripe. It is directly under the intake manifold, but I can't for the life of me find any more open plugs!! (EG's harness onto a b18b1.) I looked back on the d15 but can't find a place for it there either which doesn't make any sense because I just took it off of there an hour ago.</TD></TR></TABLE>
Maybe the purge control solenoid valve connector? I don't remember the wire number/colors of that plug but it can be easy to overlook and should be in the same general area.
Old Dec 3, 2005 | 06:20 PM
Default Re: I need someone to check their EG for me... (xavenged7x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xavenged7x &raquo;</TD></TR><TR><TD CLASS="quote">Maybe the purge control solenoid valve connector? I don't remember the wire number/colors of that plug but it can be easy to overlook and should be in the same general area.</TD></TR></TABLE>
Cancel what I said last. There are actually 2 plugs that I can't find a home to. There is seriously NOTHING. I don't know how this can even happen. I can't find the plugs on the d15 either. expletive this is frustrating...
Old Dec 3, 2005 | 08:06 PM
civic_driver's Avatar
the plugs in that area are IACV, IAT, TPS, MAP sensor, EGR/perge solenoid and i think that's it
Old Dec 4, 2005 | 03:18 PM
Default Re: (civic_driver)
I'm a moron. It was for the EGR purge solenoid. I forgot that I had left it attached to the civic...
B_Swapped93
Mar 8, 2017 03:05 AM
ed3tsmith
Jan 26, 2009 08:24 AM
sleeper759
Jul 5, 2007 04:37 PM
BlKdOutEk
Sep 22, 2005 08:09 PM
DieMaster
Sep 1, 2005 12:39 PM
