help me decide
Old Dec 3, 2005 | 03:48 PM
allmotorek8's Avatar
Modified by allmotorek8 at 12:09 AM 12/5/2005
Old Dec 3, 2005 | 08:03 PM
Terrible One's Avatar
Default Re: help me decide (allmotorek8)
with pr3's compression will around 11.3ish, with pct it'll be at 12.8ish (i think). so if you wanna run pump gas go with the pr3's. you'll need parts off that b16 block to do the ls/vtec.
Old Dec 3, 2005 | 08:11 PM
onepoint6i's Avatar
first off, you cant really reuse pistons when they are removed from the original rods, most of the time they break because the rod has to be heated up to remove the wristpin/piston..
You're gonna have to buy some pistons for sure,so buy some p30 pistons and call it a day..
Old Dec 3, 2005 | 08:23 PM
slo blue's Avatar
Default Re: help me decide (onepoint6i)
use the pr3's or p30's or p73's
Old Dec 4, 2005 | 12:12 AM
Default Re: help me decide (slo blue)
ok so im think im goin to go wit the pr3's in the ls block wit ls crank? what else u guys think ima have to get i know so far im gettin arp rod bolts , aebs head studs, new bearings and stuff for the block, vtec oil,water, fuel pump, timing belt? anything else?
Old Dec 4, 2005 | 12:15 AM
xEnderx's Avatar
I refuse to comment based on the fact that you use e-grammer. Take the extra time to type in normal english and you'll sound alot more intelligent.
Old Dec 4, 2005 | 12:18 AM
onepoint6i's Avatar
Default Re: help me decide (xEnderx)
Old Dec 12, 2005 | 09:19 PM
how bout u blow me u ******
damndude_92
14
Apr 15, 2009 05:16 PM
slayersluck
Dec 6, 2004 11:01 AM
pane93civhb
12
Oct 20, 2004 02:09 PM
teamrushhatch
Jun 1, 2003 03:08 AM
REDBARON
Jan 12, 2002 06:43 AM
