How many quarts of oil need to be burned before the CEL comes on?
Old Mar 14, 2002 | 07:29 AM
Cosworth's Avatar
Default How many quarts of oil need to be burned before the CEL comes on?
So, when does the CEL comes on after burning how many quarts of engine oil? I'm just curious... 'cuz I think I burned ~.5 quarts during my trip from ATL -> Keys -> ATL (~2000 miles). Of course, I have added back the oil.
btw, the oil dip stick... the top hole is for 4 quart mark, correct?
Old Mar 14, 2002 | 07:51 AM
DutchITR1689's Avatar
Default Re: How many quarts of oil need to be burned before the CEL comes on? (Cosworth)
The difference between the upper and the lower mark is 1 liter. I guess when it's 0.5L below the lower mark your CEL will light up occasionally... IMHO
Old Mar 14, 2002 | 09:08 AM
Darkteg's Avatar
New User
Default Re: How many quarts of oil need to be burned before the CEL comes on? (EuroITR1689)
errr, don't count on in, and you better NOT try..
Old Mar 14, 2002 | 09:16 AM
tegtyper's Avatar
the CEL will not come on as a result of low oil
The OIL light will come on when the oil pump cavitates (sucks air) this is measured by a pressure loss. If this light comes on, turn the ignition off immediatly, regardless of where you are.
Old Mar 14, 2002 | 10:20 AM
jmb's Avatar
jmb
since when the CEL light come on when you are burning oil?
[Modified by jmb, 1:20 PM 3/14/2002]
Old Mar 14, 2002 | 10:21 AM
Cosworth's Avatar
Default Re: How many quarts of oil need to be burned before the CEL comes on? (jmb)
My bad... the oil light.
Old Mar 14, 2002 | 11:07 AM
ZygSpeed's Avatar
By the time the oil light comes on you might be as much as two quarts low (only about 2 Qts. left)!
Old Mar 14, 2002 | 11:18 AM
B2FiNiTY's Avatar
Default Re: How many quarts of oil need to be burned before the CEL comes on? (zygspeed)
Scary...
Old Mar 14, 2002 | 11:28 AM
Trey's Avatar
25 Year Member
Default Re: How many quarts of oil need to be burned before the CEL comes on? (B2FiNiTY)
Usually if the light is on and you don't turn the motor off immediatly, your engine is focked!
I burn oil like crazy and have been 2 qts low and the light never came on.
Fear the light!
Old Mar 14, 2002 | 12:33 PM
dustin's Avatar
Default Re: How many quarts of oil need to be burned before the CEL comes on? (Trey)
Oil light was flickering on for an instant w/ sudden stops (red light, etc) in my CRX.
Spun a bearing 2 quarts low apparently.
Old Mar 14, 2002 | 12:37 PM
Warren's Avatar
Wrong-Way Wang
Default Re: How many quarts of oil need to be burned before the CEL comes on? (dustin)
That oil light might as well be a green dollar sign.
More than likely, you'll drop out of VTEC first. I've had this happen to me once on a skidpad w/ r compounds. Don't have a (edit) baffled oilpan, and the oil was a little low, but it kicked me out of VTEC w/o the oil light ever coming on.
Warren
[Modified by Warren, 5:16 PM 3/14/2002]
Old Mar 14, 2002 | 01:02 PM
Black R's Avatar
25 Year Member
Default Re: How many quarts of oil need to be burned before the CEL comes on? (Warren)
.....hehe, in my beater the oil lite will blink on in hard turns.
No problems as yet (knock on wood).
Old Mar 14, 2002 | 02:28 PM
Grandprix's Avatar
Default Re: How many quarts of oil need to be burned before the CEL comes on? (Black R)
If the dipstick has just a little bit (like 1mm) of oil on it, how much is in your pan? I guess from reading above, you are 1.5 litre low. That still leaves 2.25 litre or so left in the pan.
Old Mar 14, 2002 | 02:52 PM
dustin's Avatar
Default Re: How many quarts of oil need to be burned before the CEL comes on? (Grandprix)
No most of that oil is in the motor =P
Old Mar 14, 2002 | 03:05 PM
sgT's Avatar
sgT
Thats because vtec needs 30psi, the oil light comes on below *3* psi.
The dipstick measures the LAST 1 quart. If you are off the stick you are
at least 1 low. Usually the light will come on when you are around 1 qt.
Old Mar 14, 2002 | 03:15 PM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
Warren
This can in fact cause a CEL. Code 22 for the VTEC Oil pressure switch malfunction, so I guess low oil technically can throw a CEL in a way..
Old Mar 14, 2002 | 03:29 PM
DC5 Type-R's Avatar
New User
Default Re: How many quarts of oil need to be burned before the CEL comes on? (FL n NC rock j00)
I have problem with one of the ABS sensor, how come the ABS light never comes on and I have to use a jumper wire to check out the code??
Old Mar 15, 2002 | 05:58 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
if your oil light comes on, you have between 1.5 and 2 quarts in the motor! 2 quarts low! don't ask me how i know this.....
Londo2557
Nov 28, 2016 07:27 AM
itzyaboyzeem03
Jul 1, 2016 04:40 PM
Cashflo
Sep 26, 2006 01:47 PM
TEGME
Jan 28, 2003 12:03 PM
t0p_sh0tta
Nov 19, 2002 07:12 AM
