92-95 Civic Brake upgrade
The Integra set up works fine, and will be a big difference over the stock set up. I have done it on my CX and have been happy with it.
Simple process. Do stainless line upgrade too!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.6t »</TD></TR><TR><TD CLASS="quote">What is the largest size brakes I can put on my 95 Civic CX project without having to modify.</TD></TR></TABLE>
that was not the smartest thing i've heard. you cannot mount integra calipers on your CX without using the inregra hubs. the mounting brackets are too small on your CX
Integra brakes front and rear will be a massive improvement over the stock CX disc/drum setup. You absolutely do NOT need more than this on the street, with proper pad choice.
Any of the Integra spindles will work, as they're all the same (DC, not DA teg). The Civic Si spindles will also work apparently, though I can't confirm that from personal experience. I'd recommend being safe and just get the DC teg ones.
TomCat39
12
Jan 19, 2015 06:28 AM
_gurusan_
Dec 5, 2005 11:41 AM
Yellow Dragon
Apr 16, 2002 10:19 AM
