b16/ef OBD0 ....check engine light is on but ecu isnt showing any codes
Old Dec 2, 2005 | 02:03 PM
drew2's Avatar
Default b16/ef OBD0 ....check engine light is on but ecu isnt showing any codes
PR3 ecu
car wont rev above 3k
just put a new headunit in and then it started doing this
the check engine light is on but the LED on the ECU isn't flashing, its just on steady
its been awhile since ive read codes on this but i dont remember having to do anything, should't they just be blinking in the LED?
Old Dec 2, 2005 | 02:39 PM
aka's Avatar
aka
disconnect the bttery or pull the #ten fuse and reset the ecu. do you have a code
Old Dec 2, 2005 | 03:01 PM
MonkeyMagic's Avatar
Default Re: b16/ef OBD0 ....check engine light is on but ecu isnt showing any codes (drew2)
that'd be the symptoms of a bum ecu..
EF8IGHT's Avatar
thats weird it happened to me also and i cahnge my ecu out to a pr3 chiped and the changed it out again to the same on and it worked fine i dunno tho its weird
Old Dec 2, 2005 | 05:02 PM
drew2's Avatar
Default Re: b16/ef OBD0 ....check engine light is on but ecu isnt showing any codes (EF8IGHT)
DAMN, went back out and its dead, wont' do anything. Tried to jump it and dash lights come on but doesnt crank at all. WTF
This all happened right after i put a new headunit in so i unplugged the head unit just in case it was shorting something but made no difference
ideas?
Old Dec 3, 2005 | 10:20 AM
drew2's Avatar
anyone? is there another ecu that i can stick in just to see if that is the problem...i dont have anothe PR3 handy, what else will work
would the car run on a 90 SI computer (i dont care if the vtec works, just to make it run)
Old Dec 3, 2005 | 10:54 AM
mahatma's Avatar
It's got to be a fuse. Check all your fuses.
Old Dec 3, 2005 | 11:51 AM
drew2's Avatar
Default Re: b16/ef OBD0 ....check engine light is on but ecu isnt showing any codes (mahatma)
checked all the blade type fuses, both engine bay and in the car, none are blown
is there a way to test the ECU? i dont know anyone w/ a pr3/pw0 that i can borrow
What ECU's can this setup run?
OBD0: pr3, pw0
OBD1: ????
and as i said before, is there anything else that will make it run but maybe not well or w/o vtech (so i could get the car home to work on it)
Modified by drew2 at 9:12 PM 12/3/2005
jfields06
Dec 27, 2008 06:42 AM
crxtreme27
Jul 1, 2003 04:30 PM
CleanLIttleLude
Jun 13, 2003 12:09 PM
Norcalstoppy
Jul 11, 2002 06:26 AM
