Idle Woes.
I recently got a 1993 Teg and it has developed a strange idle problem. It idles normal until it warms up some, at that point it will bounce between 1000 and 2200 rpms, also if it is in gear and I press the throttle and let off fast it will stick for a second and rev higher (300-500 rpms) and then drop to about 800 rpm then go back to bouncing if its in nuetral. I have cleaned the IAVC which made it not bounce as iradically, I drove with the iavc disconnected and it ran like **** at lower rpms but the symptoms went away. I am getting no codes also.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">Are you sure you're not leaking anywhere?</TD></TR></TABLE>
I am gonna check that tommorow but I am pretty sure I am getting no leaks. Any other causes Honda-Tech?
