Suspension & Brakes Theory, alignment, spring rates....
help with strut bar
Old Dec 2, 2005 | 08:12 AM
nurvcom..'s Avatar
Default help with strut bar
I HAVE 95 CIVIC DX
and i got 2 strut bars and front one i dont know how to install?
help
nurvcom
Old Dec 2, 2005 | 08:46 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: help with strut bar (nurvcom)
Most civics & integras have holes already drilled for that bar in the proper location. They should be pluged with rubber grometts that are painted the same color as the car. If you do not have the grometts & holes, your going to have to drill. To find the correct spot, I've heard that the proper location for the holes can be located by looking up into the fender (above the upper control arm). The shock tower is constructed of two metal panels welded together. I've heard that the bottom layer should always have the holes (this is hear-say though ). Then all you do is drill up through them into the engine bay (keep wires away ).
Oh yeah, your going to need 4 short grade 10.2 metric bolts, matching nylon lock nuts, and 8 washers
This is what it's supposed to look like installed...
Old Dec 2, 2005 | 10:37 AM
nurvcom..'s Avatar
Default Re: help with strut bar (94eg!)
ok thanks
that helps tons
Old Dec 2, 2005 | 03:32 PM
nurvcom..'s Avatar
it done
i got to tall of bolts
Old Dec 2, 2005 | 03:58 PM
94eg!'s Avatar
#1 Super Guy
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nurvcom &raquo;</TD></TR><TR><TD CLASS="quote">it done i got to tall of bolts</TD></TR></TABLE>
LOL, I said "short"...
Old Dec 3, 2005 | 10:24 PM
nurvcom..'s Avatar
i know i aready fix them with shorter ones but thanks for help
termite1r
Apr 24, 2013 09:17 PM
NsX_CrX
Jul 17, 2006 06:02 PM
h22vt
Mar 21, 2006 03:49 AM
rMak
Aug 5, 2003 02:58 PM
