stroker kit and turbo question
99 Civic Si B16A2
i will be installing the toda B16A stroker kit. are there any mods i have to do to make it work like fuel system, ECU??
with that and a turbo running 10-12 psi, should i use lower compression pistons than what comes with the stroker kit or should the engine be able to take that high compression??
stroker kit info
stroker kit info
So you're thinking of buying another set of pistons on top of the ones that come in this kit? You gotta think this through. This kit is an NA application anyway.
BTW, where have you been lately?
11.0 is a mighty high compression ratio, it can be done, but one minor fuel mistake and you'll nuke your motor. You must have a lot of cash to waste. Have you looked at the golden eagle kits. Better yet why not build a gsr for boost or somthing there is a reason honda added 10 or so mm, to the deck on the 1.8 litre motors.
i know its NA but im gonna make it work. one way or another the 2 will be combined on my engine. just looking for some ideas incase i overlooked something. and before someone says it, money is not an issue so dont say it.
the job doesnt send me home so i stay and make the money.
ya ok so if i cant get it done on the $15,000.00 i have set aside for it, then it will have to wait until i can get more to finish.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath »</TD></TR><TR><TD CLASS="quote">ya ok so if i cant get it done on the $15,000.00 i have set aside for it, then it will have to wait until i can get more to finish.</TD></TR></TABLE>Ok, so you have 15k. Cool. Do you know what turbo setup you're going with?
If I had 15 grand i wouldnt spend it on those parts, I'd buy a k20 and boost it and spent the rest on something that is going to apprectiate in value and then smile as I blow the doors off your setup.
why not use a b17 crank and pistons in the b16 block? thatll produce a stroked b16 i believe.... and i seen b17 parts floating around the marketplace
only issue is getting any type of forged rods for a b17 is a pricey undertaking...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime »</TD></TR><TR><TD CLASS="quote">why not use a b17 crank and pistons in the b16 block? thatll produce a stroked b16 i believe.... and i seen b17 parts floating around the marketplace
only issue is getting any type of forged rods for a b17 is a pricey undertaking...</TD></TR></TABLE>The dude has $15k ... you think b17 rods will be an issue.
-Red
-Red
im getting a custom made turbo that spools around 4000 rpm's so it produces the most power from there to 8000. dont know exactly which other parts im matching with it yet. turbo will be added at a later date
just need to know what mods need done for the stroker kit like the ecu, fuel injectors, pump, curve. anything like that need to be done to make the stroker kit work??
