Stroker Kit?
Old Jan 15, 2011 | 08:32 PM
dev203d's Avatar
Icon2 Stroker Kit?
I'm being given the option to buy a used GSR block that's sleeved with a stroker kit for 2,000. Not sure of the brand of the kit, but any worries on a stroker kit if I'm going turbo? I am rather unfamiliar with them.
Old Jan 15, 2011 | 10:57 PM
Spawne32's Avatar
Default Re: Stroker Kit?
if its sleeved and has the kit installed, no probably not, you just have to verify the compression ratio, remember though the stroker kit is gona move your peak power way down in the rpm's.
Old Jan 16, 2011 | 12:58 PM
jdm_bones's Avatar
I would gather more info on the type of kit it is, and the compression ratio that it is running. You should never buy something that you really dont know history on or spec's. That's my .02
Old Jan 16, 2011 | 01:53 PM
94 ls-r's Avatar
Depending on stroke. Stroker kits give way more torque but less revs. Find out the stroke and kit. Find the compression ratio too.
Old Jan 16, 2011 | 06:19 PM
dev203d's Avatar
Thanks guys, I will have the stroke and compression ratio posted up here by Tuesday hopefully. Would a turbo block with a stroker kit be something nice? I'm thinking you lose the high revs but gain TQ and the turbo makes up for higher end HP so isn't it the best of both worlds?
Old Jan 16, 2011 | 06:36 PM
Spawne32's Avatar
dont let anyone talk you out of a stroker kit, if you can get one for the right price, go for it, the only reason it isnt a common practice around here is because people swear by their high revving 9000rpm vtec engines, and dont see the point of spedning 2 grand for one of the stroker kits.
Old Jan 17, 2011 | 04:45 PM
jdm_bones's Avatar
I like Knife edged balanced LS crankshafts with aftermarket forged rods that are 89mm with an OEM piston of your choice depending on the compression ratio you are looking for, to be used on my B18C1 setups. I feel that is cheaper then a aftermarket kit. Works for me my .02
Boostin_GSR
Jun 15, 2007 05:26 PM
got_boost16
Jan 29, 2006 06:14 PM
civictildeath
10
Jan 16, 2006 09:13 PM
da'ee
May 4, 2005 12:47 PM
s2kkid
Dec 26, 2004 06:52 PM
