Ls/Vtec Pistons and Rods question
Old Dec 2, 2005 | 03:47 AM
JDM90SiR's Avatar
Default Ls/Vtec Pistons and Rods question
Im running the stock LS crank balanced and PR3 Piston. Can you recommend a good H beam rod or a good rod period i should use?
Thanks
Old Dec 2, 2005 | 07:23 AM
JDM90SiR's Avatar
Default Re: Ls/Vtec Pistons and Rods question (JDM90SiR)
Bump
Old Dec 2, 2005 | 07:28 AM
Kendall's Avatar
With OEM pistons you'll need OEM rods unless you plan on having additional machine work done to the pistons. I'd just use a good set of LS rods and get the rotating assembly balanced.
caster troy si
Sep 20, 2006 03:12 PM
trincivic
Oct 20, 2004 02:02 PM
turboteggsr
Jun 12, 2004 12:20 AM
b16vtecsol
17
Nov 11, 2003 05:27 PM
Wazup
May 7, 2003 08:26 AM
