ls/vtec swap, how much should i be paying?
Old Dec 1, 2005 | 09:00 PM
ekcivic9's Avatar
Default ls/vtec swap, how much should i be paying?
hey guys
i was wondering what the "average" cost of getting everything needed for an ls/vtec swap?
i was quoted 2500 for an ls/vtec with manual conversion part.
is this too much? the car was in a accident where it rolled, but it still cranks.. so i dont know how everything is. should i skip on this?
thanks
Old Dec 1, 2005 | 09:03 PM
my_slow_civic's Avatar
Default Re: ls/vtec swap, how much should i be paying? (ekcivic9)
Is that just for the "swap", or the swap+labor to put it in?
$2500 sounds a little steep, but it depends what has been used.
Old Dec 1, 2005 | 09:04 PM
ekcivic9's Avatar
well id be swapping it myself... lol id like to see that happen. but yeah i thought it was a little on the expensive side.
Old Dec 1, 2005 | 09:07 PM
11SEC CIV's Avatar
Default Re: (ekcivic9)
well what does the $2500 include?
is it built? stock? full swap (ie..trans/harness/ecu/linkage/axles etc..)
Old Dec 1, 2005 | 09:21 PM
ekcivic9's Avatar
yes full swap gsr, sorry i should have been more clear with that.
the shift linkage might be bent from the roll. but the pedals and master cylinders for the auto ->manual conv should be fine.
Old Dec 1, 2005 | 09:24 PM
11SEC CIV's Avatar
sorry if i seemed confused but this is ls/vtec installed in car already but it was rolled?? and its auto??
Old Dec 1, 2005 | 09:28 PM
hapexamendios 2.0's Avatar
R.I.P.
Default Re: (12SEC CIV)
and if its a "full swap gsr" wheres the ls/vtec part come from?
Old Dec 1, 2005 | 09:45 PM
ekcivic9's Avatar
no no... my car is currently auto.
the car w/ the swap was rolled. ls block with gsr head and gsr tranny.
Old Dec 1, 2005 | 09:48 PM
Defile's Avatar
Doesnt seem to steep to me, considering a gsr tranny alone is like 800, and if your doing an auto to manual conversion, i'd say its not to bad a deal...
Old Dec 1, 2005 | 10:16 PM
HiProfile's Avatar
Default Re: (Defile)
The only thing I'd be concerned about is oil starvation when it rolled, mainly if it came to rest on it's side or roof. People usually aren't concerned or thinking about turning their engine off after a roll. The first three things are - is their *** in 1 peice, is their car in 1 peice, and can they sue the other guy.
2500 for a full swap and an auto->manual conversion is good imo. Considering people are paying ~3k for a good GSR motor/trans alone, its def. somethign to think about. Personally I'd look the bottomend over first (bearings) before handing the cash over, or have them sign a short contract stating a full refund will be given if the motor has any noticable oil starvation (based on your opinion or that of a trained mechanic).
If I were you, I'd also steal the fuel pump off the car too, since even an LS pump is more powerful than most EG pumps.
Old Dec 1, 2005 | 10:19 PM
TheLastSpartan's Avatar
Well, so far I've spent $2K+ on my setup and I still don't have a tranny,axles and shaft (last things I need). But then again, I've already got ITR cams, Skunk2 camgears, etc. so I can just put it in all at once. Like them other guys said it just depends on what's being used.
Old Dec 2, 2005 | 02:04 AM
Ic3Man's Avatar
well i say it is a little much for the whole thing. you should just build the ls vtech yourself and save some money. i don't know if its just me but i could do it for $600-$800 for the whole motor. with tranny harnesses mounts the works. it could just be me cause i don't know how much you guys could do it for.
Old Dec 2, 2005 | 03:27 AM
litterbox's Avatar
I am a (Trial User) Army
Default Re: (Ic3Man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ic3Man &raquo;</TD></TR><TR><TD CLASS="quote">well i say it is a little much for the whole thing. you should just build the ls vtech yourself and save some money. i don't know if its just me but i could do it for $600-$800 for the whole motor. with tranny harnesses mounts the works. it could just be me cause i don't know how much you guys could do it for.</TD></TR></TABLE>Pass the crack pipe.
Old Dec 2, 2005 | 08:09 AM
HiProfile's Avatar
Umm, yeah. Pass that **** you're smoking. I could also buy the entire Microsoft Corporation for a couple mil, but it requires what you need for that - a fist full of LUCK. A shortblock for $150, a head/intake/harness for $350, tranny for $300. That, of course, it waiting for each component to pop up, getting to it first, and taking the chance that it's still in prime condition. If you can get a perfectly working LS/VTEC setup for $800, I'll give you $1000 plus shipping (hell, I'd send you a couple prepaid crates!) if you can deliver on that promise.
Edit: I could actually pick it up, since I have good friends in Tenn.
jdmdikk
Jul 6, 2008 08:55 AM
Gimpo
Apr 12, 2004 09:48 PM
ninety9blackEX
Mar 21, 2004 07:38 AM
BADGUYNY
Aug 2, 2002 08:06 AM
