Throwout bearing making noise. Loss in performance?
Old Mar 13, 2002 | 09:06 PM
SiKSiR's Avatar
Default Throwout bearing making noise. Loss in performance?
My throwout bearing is making a chirping type of noise that goes away when I depress the clutch pedal. Will I lose any performance if my throwout bearing is making this noise or will I just be faced with the noise? Is there any way to fix it? And if I buy a new clutch, most likely exedy organic, will it include a new throwout bearing or do I just adjust the old one?
Old Mar 13, 2002 | 10:47 PM
PoWeRBaN_PaNdA's Avatar
Default Re: Throwout bearing making noise. Loss in performance? (SiKSiR)
i had the same problem it's the throwout bearing just get it repalced and you will be fine
Old Mar 14, 2002 | 03:21 PM
SiKSiR's Avatar
Default Re: Throwout bearing making noise. Loss in performance? (notec_racer)
What if it does not get fixed. Will it cause a loss in performance?
Old Mar 14, 2002 | 05:34 PM
Jesse H's Avatar
not being able to shift? yeah, that's a performance bummer
Old Mar 14, 2002 | 06:59 PM
dirtySOHC's's Avatar
Default Re: Throwout bearing making noise. Loss in performance? (Jesse H)
replace it as soon as possible. about the clutch......you are gonna have to check with them.
i wanna ask how your civic is running with the iridium plugs? or
[Modified by dirtySOHC's, 4:01 AM 3/15/2002]
StockDC2
Jul 8, 2017 11:48 AM
93 EG
12
Mar 3, 2007 08:14 AM
00siandrew
Apr 13, 2006 05:09 PM
sracing
Aug 27, 2003 09:50 AM
