if i go turbo will i HAVE to upgrade fuel pump?
i am goint to put the 92-95 greddy turbo on my zc do i have to get a new fuel pump or will a fmu work? please let me know thanks i will only be running like 8 psi max
Yes, put a high flow intank, or inline pump in the car at the time of the turbo install! Choose the fuel pump depending on your application!
most of the time you will have to upgrade... depends on what injectors you'll run and your FMU.
ultimately, a dyno run with a wide band O2 will tell you the condition of your fuel
