Please help I do not know whats going on with my tranny!
Old Dec 1, 2005 | 03:00 PM
B89HatchSi's Avatar
Default Please help I do not know whats going on with my tranny!
Well I droped a manuel B16 with LSD in my 89 Hatch Si, everything starts and runs great. But I went to drive it and when I make right hand turns it starts to grind and then as the turn gets sharper the sound turns to like a poping with the grind, and I can feel it in my stearing wheel. So I go to make a left hand turn and the sound it only a light grind and no popping. And when going straight no sounds or nothing its smooth as can be. I thought it was the C/V joint so I replaced the new axles with another and the same thing. I replaces my tranny fluid to make sure and there was no metal or anything in it. But I filled it back up with the 2.5 quarts of Honda Manuel Tranny fluid. I have no clue what it is, my buddy thinks it may be the LSD going bad. I am not sure. Someone please help!!!!!
Old Dec 1, 2005 | 03:51 PM
temp's Avatar
Default Re: Please help I do not know whats going on with my tranny! (B89HatchSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B89HatchSi &raquo;</TD></TR><TR><TD CLASS="quote">Well I droped a manuel B16 with LSD in my 89 Hatch Si, everything starts and runs great. But I went to drive it and when I make right hand turns it starts to grind and then as the turn gets sharper the sound turns to like a poping with the grind, and I can feel it in my stearing wheel. So I go to make a left hand turn and the sound it only a light grind and no popping. And when going straight no sounds or nothing its smooth as can be. I thought it was the C/V joint so I replaced the new axles with another and the same thing. I replaces my tranny fluid to make sure and there was no metal or anything in it. But I filled it back up with the 2.5 quarts of Honda Manuel Tranny fluid. I have no clue what it is, my buddy thinks it may be the LSD going bad. I am not sure. Someone please help!!!!!</TD></TR></TABLE>
me thinks your buddy is right
Old Dec 1, 2005 | 03:54 PM
88 rex's Avatar
Default Re: Please help I do not know whats going on with my tranny! (temp)
Me thinks so too........especilly if you have new axles.
Old Dec 2, 2005 | 04:37 AM
B89HatchSi's Avatar
Default Re: Please help I do not know whats going on with my tranny! (88 rex)
come on guys 34 views and 2 posts, please help!!!!!
Old Dec 2, 2005 | 05:43 AM
88 rex's Avatar
What more do you want from us. We can only speculate, and have put forth a resonable answer. The only true way to find out is to drop the tranny and crack it open.
Old Dec 2, 2005 | 06:51 AM
crx_88_si's Avatar
what axles did u use? (u never mentioned and could be a cause of this too)
Old Dec 2, 2005 | 07:47 AM
B89HatchSi's Avatar
Default Re: (crx_88_si)
I used brand new axles from a 90 Integra with no ABS.
Old Dec 2, 2005 | 07:52 AM
temp's Avatar
Default Re: (B89HatchSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B89HatchSi &raquo;</TD></TR><TR><TD CLASS="quote">I used brand new axles from a 90 Integra with no ABS.</TD></TR></TABLE>
assuming that you are using integra front brakes or D series outer axle thingys (technical term :-P). then i give you this, expletive YOU. we gave you an answer, and because you didnt like what you heard you asked for more, again expletive YOU.
90 JDM EF8
Sep 25, 2007 06:13 PM
b16edeg
Sep 24, 2007 05:21 PM
QuickDxEk
Aug 1, 2006 06:58 PM
B89HatchSi
Dec 2, 2005 07:55 AM
yaya
12
May 22, 2003 02:05 PM
