HX Turbo
Old Mar 13, 2002 | 07:54 PM
EVIL Hx Coupe's Avatar
Default HX Turbo
anyone knows of a turbo kit for the HX. If theyd on't make one can someone suggest what i should get.
Thanks
Old Mar 13, 2002 | 07:57 PM
Troy's Avatar
Default Re: HX Turbo (Boost Pressure)
the Greddy turbo kit for 92-95 Civic would fit fine, ur tranny might mess up after a while though!
Old Mar 14, 2002 | 10:06 AM
Spade's Avatar
Any of the kits made for the Civic will work. The only issue is the exhaust. If it was made for the EX then you are going to have to relocate the cat and cut your exhaust back to under the car instead of it flowing all the way up in front of the engine.
Old Mar 14, 2002 | 10:17 AM
VTC_CiViC's Avatar
Default Re: HX Turbo (Spade)
Just get an EX cat and EX spec catback, or have a shop custom make you a test pipe and use any EX spex catback. (Factory Si catback is a cheap alternative over D16 piping).
Old Mar 14, 2002 | 11:57 AM
Is the transmission on the HX's that bad???? If it is what transmission bolts on the HX. (a good one)????
Old Mar 14, 2002 | 12:02 PM
Spade's Avatar
The only issue is the fact that it has such tall gearing.
Any D series tranny of same generation will bolt on. It would be very benificail if you plan on going turbo on the HX to get a EX transmission with a LSD (gear type).
Old Mar 14, 2002 | 12:20 PM
DragII's Avatar
25 Year Member
IMO the HX is a poor canditate for turbo based on the length of vtec engagement, and ecu's fuel programming.
Old Mar 14, 2002 | 12:25 PM
Spade's Avatar
Default Re: HX Turbo (EvilDragII)
You mean because the VTEC is engaged too long!?! starts at 2700 (if pedal is smashed)
Fuel maps: You totally have my vote, get a VAFC if you plan on running the HX ECU.
Old Mar 14, 2002 | 12:26 PM
DragII's Avatar
25 Year Member
yes, exactly!
Old Mar 14, 2002 | 12:51 PM
Spade's Avatar
But, if you use a VAFC or a different ECU then you would have a proper or more desirable VTEC engagement wouldn't you?
Or you could just purchase an EX head, have it ported and polished while you run around on the HX head.
Old Mar 14, 2002 | 01:27 PM
Jaminak's Avatar
Why is VTEC enganged too long a bad thing?
-Jamin
Old Mar 14, 2002 | 01:37 PM
DragII's Avatar
25 Year Member
Default Re: HX Turbo (Jaminak)
-Jamin
Overlap ring a bell?
yeah spade...you could infact do that...how is the low cam on the HX though....would this set up make very little power, or would it be comperable to the ex
Old Mar 14, 2002 | 01:40 PM
Spade's Avatar
Low cam sucks!!!
It....hm how to explain......well, the horsepower on the low cam is 50ish at 3000!
If that.
Basically even though the low lobe opens, it almost feels like I am driving around on a 12 valve engine.
Spade - Who doesn't really drive around under 3200 RPM and shifts at 5000 daily driving. aand and and, clutch isn't fully let out with the RPM's lower than 2000 from a stop.
EDIT: If the EX tranny was used then you would always be on the high cam anyway so, you would save on gas but, if your installing a turbo you can kiss that goodby to begin with anyway.
[Modified by Spade, 2:42 PM 3/14/2002]
Old Mar 14, 2002 | 01:42 PM
DragII's Avatar
25 Year Member
oh my! well....I guess to sum it all up...Turbo-ing the HX can be done w/ the help of a VAFC....any EX kit will work, and you may, or may not be happy w/ your results
Old Mar 14, 2002 | 01:47 PM
Spade's Avatar
Nod. I have chosen to just finish the suspension on the HX and then eventually trade that in for the family car. The EX is going to get the build up and turbo. Much like VTC only a LONG way down the road.
Spade - Who hopes Greddy will get that damn turbo kit for the 96-00 EX done and CARB legal!!!
supa-shocka97
Oct 30, 2011 06:19 PM
PhatBoy5015
Jun 2, 2004 06:27 PM
2000blackgsr
Apr 2, 2003 02:08 PM
arf
Dec 9, 2001 08:33 AM
