Easy way to seperate tranny from block?
Old Mar 13, 2002 | 07:28 PM
Mario's Avatar
Default Easy way to seperate tranny from block?
What's the easiest/most effective way to seperate the tranny from the block. The engine is off the car and is sitting on my garage floor. I've tried and tried but nothing would work. I tried the prying points, no luck. Any other tip?
TIA
Old Mar 13, 2002 | 07:34 PM
ALF's Avatar
ALF
Default Re: Easy way to seperate tranny from block? (Supersonic DC2)
So you have taken off all the bolts and the tranny won't come off? Hmm...
Old Mar 13, 2002 | 07:43 PM
rainforest's Avatar
Default Re: Easy way to seperate tranny from block? (Dozed)
rubber mallot. and a punch.
Old Mar 13, 2002 | 07:47 PM
Ri5e's Avatar
Default Re: Easy way to seperate tranny from block? (rainforest)
There are some dowel pins in between. Get big *** Flat headscrew driver, put in between and try to crack it open.
Old Mar 13, 2002 | 07:57 PM
3rdGteg's Avatar
Default Re: Easy way to seperate tranny from block? (BG Boost)
How hard is it to pull the tranny off with the motor still in guys? And is it hard to get it back on with motor in?
Old Mar 13, 2002 | 09:56 PM
sleeper4dr's Avatar
Default Re: Easy way to seperate tranny from block? (3rdGteg)
i'd say that sometimes its actually harder to pull the tranny from the block when its OUT of the car. when the engine/trans are still in the car, at least its bolted to something so you can get some leverage on it.
pulling the trans from the motor while still inside the engine bay is not that difficult. though re-aligning from underneath is a real bitch by yourself. holding that ~75lb thing up while trying to line up the shaft splines with the clutch can be a PITA.
hth, J
Old Mar 14, 2002 | 06:25 AM
Crazydave's Avatar
Default Re: Easy way to seperate tranny from block? (sleeper4dr)
I've pulled a tranny off a motor when it was in the car.. and out..
both times were equally as easy..
make sure you have *ALL* the bolts out... start at the top and go alll the way around....don't forget the brackets that mount at the bottom next to the dust cover
a little wiggling is all it needs.. or a few wacks with a rubber mallet.....
Old Mar 14, 2002 | 09:50 AM
Lsos's Avatar
I've taken off quite a few trannies, and each time the same thing happens: I get pissed off because it's so close to coming off, I check and double check all the tranny bolts and the dust shield bolts. I try again, I get pissed....
Then my friend comes to help, asks if I got all the bolts, I say yeah, he checks anyways and finds one that I missed. Must have happened like five times by now.
Old Mar 14, 2002 | 11:11 AM
Kamin's Avatar
dont forget the starter bolt
Old Mar 14, 2002 | 11:42 AM
Katman's Avatar
TIA
lol...(I'm gonna be an *** right now) Did you take all of the 17mm bolts out? haha.
jk..
if you have all those 17mm bolts out, make sure you have the FLYWHEEL'S 10mm DUST COVER BOLTS removed from the underside, where the tranny meets the block. Starter bolts also need to come out. It should easily come apart..or a small gap should open up between the trans and block which will allow you to seperate the 2 with a pry bar. If you have a cable tranny, just pull UP on the cable lever and the tranny should, sort of, pop off...
Old Mar 14, 2002 | 06:56 PM
Mario's Avatar
Problem solved! Thanks everyone.
Old Mar 14, 2002 | 07:24 PM
3rdGteg's Avatar
Default Re: (Supersonic DC2)
Now if I can get the tranny off, how hard would you guys say changing the clutch is?? Any special tools, jack, etc.??
Old Mar 14, 2002 | 08:04 PM
Mario's Avatar
Default Re: (3rdGteg)
On the same note...is a clutch alignment tool REALLY necessary? Or can I just "eye" it?
Old Mar 14, 2002 | 08:43 PM
2000_Civic_Si's Avatar
You better use a alignment tool! If not your clutch will wear uneven!
Old Mar 14, 2002 | 09:44 PM
earl's Avatar
Default Re: (2000_Civic_Si)
Huh? It won't even go back together unless the disc is aligned with the pilot bearing. If it does go together, then it has to be in alignment.
Old Mar 15, 2002 | 03:46 AM
Mista Bone's Avatar
D Tranny Guru
Tranny lift..........
Alignment tool......
3 hours to do a clutch without a frame lift.
Old Mar 15, 2002 | 06:07 AM
Kamin's Avatar
no you cannot. youll understand when you try to bold the pressure plate to the flywheel. go to autozone or checker and rent the clutch alingment tool. when you take it back they give you a full refund. its a universal tool so it works. i used it on mine. worked great
Old Mar 15, 2002 | 04:29 PM
Lsos's Avatar
Default Re: (KAMiN)
You can eye it. I do not recommend it.
I did on my b16 because the tool included in the clutch kit didn't fit at all and I didn't want to wait until tomorrow. If I had time on my hands I would have gotten the thing.
I don't see how it would affect clutch wear. In fact, I just took off my clutch the other day after a year of hard driving (about 100 time slips to prove it). No uneven wear at all.
Old Mar 15, 2002 | 05:03 PM
CivicEK.PDX's Avatar
Default Re: (Lsos)
u can eye it if you want. Also make sure the dust cover is unbolted.
Old Mar 15, 2002 | 07:36 PM
3rdGteg's Avatar
Default Re: (CivicEK.PDX)
Thanks Mista Bone for the tool list.
EH2-R
10
Apr 12, 2007 09:45 AM
nissanjon
Nov 27, 2004 09:34 PM
Rod.
Jan 20, 2004 07:24 PM
xteg95
May 18, 2003 03:49 AM
hotintegranights
Jan 5, 2003 02:13 PM
