Did I install muffler wrong
Hey guys i got a turbo muffler and i put it on. Seems a bit quiet. Is there any special way to put it on. Does it matter which pipe the exhaust gases enter and exit??? Can you put this on backward what i mean i guess is there an inlet and outlet or are they both the same??
Thanks Guys
Thanks Guys
if it looks the same as in it is interchangeable and it still fits then it is ok. there isnt and way that the gases wont flow through the pipe. if ti wasnt flowing right the car wouldnt run very well. it might just be a quiet exhaust. a friend has a turboed VR6 and his new exhaust is quiet as hell. if it still runs good feel priveledged. the cops wont look at you as often.
its prolly loud i guess i havent took over 4 K rpm and havent got tip or section from muffler to tip on yet. Would that make it quiet not haveing the section from muffler to tip on and no tip??
Thanks
Thanks
i will.... No JK i dont have a turbo. I just want more loudness!
Will putting a hollowed out cat instead of stock cat make it louder? if so how much
[Modified by 89 CRX SI, 4:40 AM 3/14/2002]
why would you want it loud, eh well heres how you get it louder, go inside..... get a phillips head screwdriver....... go out to your car............. get your screwdriver............punch a crapload of holes in the muffler..... voila, armageddon on wheels!
haha, the old punch hole in the exhaust trick.... its like yelling out your car window, pull my *** over!!!! if you want it louder, put in a test pipe, but if i can remember correctly my turbo mufflers on my domestic where quiet at idle but had a good sound at higher rpm
