Please Help!
Old Dec 1, 2005 | 08:48 AM
Hulk_EJ8's Avatar
Default Please Help!
I was driving to work on the freeway today and all of a sudden i hear this really loud clicking noise when I take my foot off the accelerator or when I brake. I don't know what it could be, anyone have a clue? Ask me any questions to help diagnose this problem. TIA
Old Dec 1, 2005 | 08:49 AM
Lee_Delso's Avatar
Default Re: Please Help! (Hulk_EJ8)
Sounds like a axle? ANy other symptoms?
Old Dec 1, 2005 | 09:12 AM
Hulk_EJ8's Avatar
Default Re: Please Help! (Lee_Delso)
no other symptoms as of yet. A bit of vibration at higher speeds?
Old Dec 1, 2005 | 09:16 AM
Lee_Delso's Avatar
1) make sure your rims are on tight
2) make sure your axle nut is tight
3) check your axles
4) check your shocks/springs
5) take it to a mech if you can't figure it out by now
Old Dec 1, 2005 | 09:17 AM
Hulk_EJ8's Avatar
Thanks lee. Im planning on taking it to a mechanic asap anyways. I hope it's nothing expensive.
Old Dec 1, 2005 | 09:28 AM
Lee_Delso's Avatar
You're welcome and good luck, but honestly I think you should be able to figure it out yourself.
Old Dec 1, 2005 | 11:07 AM
Hulk_EJ8's Avatar
OMFG..One of my studs are broken on my front wheels and out of those 3 lugs on the wheels, only 1 of them were on tight. The other two were so loose that I took them off with my fingers. Maybe somoenes trying to steal my wheels? I'm taking them off tonight and putting my stocks on there...Thanks again Lee.
Old Dec 1, 2005 | 11:13 AM
IHateJDM's Avatar
when one stud breaks, if the other 3 aren't tight enough, they will work themselves loose over time. just replace the stud and you'll be fine.
Old Dec 1, 2005 | 11:15 AM
JamesV's Avatar
mine clicked and my driver side front wheel was wobbling because my lug nuts were loose.. ( ebay lug nuts ) the teeth were worn down by the heat i guess... so yeah
1st steering wheel would wobble and feel gay
2nd car would shake
-- after that your wheel would be gone haha
Old Dec 1, 2005 | 11:18 AM
CALIdelsolSIR's Avatar
Default Re: (JamesV)
cv joint -- might need to replace the entire axle. Check axles seals too.
Old Dec 1, 2005 | 11:28 AM
IHateJDM's Avatar
Default Re: (CALIdelsolSIR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CALIdelsolSIR &raquo;</TD></TR><TR><TD CLASS="quote">cv joint -- might need to replace the entire axle. Check axles seals too. </TD></TR></TABLE>
Old Dec 1, 2005 | 12:35 PM
Hulk_EJ8's Avatar
Hey whoa. Thanks for all the help guys. After I tightened the other 3, the wheel no longer made any noises nor felt wierd. Couldn't have done it without your guys' help. Here's a drink, on me
boost4life1
40
Mar 26, 2024 08:26 PM
iinvazionii
Feb 12, 2008 04:15 PM
TunerShark
25
Nov 4, 2006 03:30 PM
jgocela
Dec 9, 2004 10:38 PM
killerboots
May 1, 2003 06:29 PM
