is this normal? or is my clutch broken?
Old Dec 1, 2005 | 05:51 AM
JamesV's Avatar
Default is this normal? or is my clutch broken?
okay when im driving or parked or starting the car..
i clutch in and the engine bay sounds okay.. once i clutch out i hear this wierd sound .. always happends i dont know if its the clutch or some internal engine bs .. but anyone think they can help me out here?
: 93 civic cx hb .. d15b7 all stock
Old Dec 1, 2005 | 05:58 AM
The_Shocker's Avatar
Is it a squeeking noise,and then you push the clutch in it stops?If so alot people I kno have that noise including myself.nuthin wrong
Old Dec 1, 2005 | 06:08 AM
JimmyAtlantis's Avatar
Default Re: (The_Shocker)
You might get better responses if you could describe the "wierd noise" a little. If it's a squeak it's probably just a spring in the clutch pedal mechanism. If it's like a whistling/squealing sound it could be your throwout bearing.
snatch's Avatar
Default Re: is this normal? or is my clutch broken? (JamesV)
Is it kind of a whirring noise that stops when you push in on the clutch, but is present when the clutch is out? If so could be bearings internal to the tranny.
Old Dec 1, 2005 | 06:11 AM
I had that noise and replaced my clutch w/heavy duty clutch and pressure plate,lightwieght flywheel,and throwout bearing replace and that little arm sits there and squeeks,its annoying
Old Dec 1, 2005 | 06:23 AM
92ehatch's Avatar
mine makes the whirring and the sqeak, so does my 94 toyota pickup.
try bleeding the system.
i have never had any problems with either clutch or MC on either car, so i dunno what it is
Old Dec 1, 2005 | 06:27 AM
mike1114's Avatar
Default Re: (93egsedan)
input shaft bearing is bad.
When you push in the clutch, noise goes away, when your just driving it makes a whirring, almost metal on metal churning type of noise right???
Input shaft bearing.
See FAQ or Sticky on how-to replace in EG Civic Section
Old Dec 1, 2005 | 06:35 AM
JamesV's Avatar
i dont know.. i'll take a sound clip in 4 hours lol -- i think you might be able to hear it.. its like a sound pitch change or like something rubbing
LandeZak
Sep 9, 2013 10:38 PM
Beezle
Oct 2, 2004 10:25 AM
Tokyo_X-treme_Racer
18
Jan 28, 2004 11:48 AM
killerslp
Jan 25, 2004 05:35 PM
rockwilda
Jun 19, 2002 03:57 PM
