grinding
Old Dec 1, 2005 | 05:37 AM
twenty's Avatar
Default grinding
if the tranny is griding into 2nd and pops out of gear when i try to put it in, whats the cause of that? syncro's?
Old Dec 1, 2005 | 06:09 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: grinding (.bump!)
Does it grind only in 2nd gear and pop out of all gears? Or pop out of only 2nd gear?
In any case, before you assume and take action against the worst, try the easy things first. Change/replace your transmission oil with something like GM Synchomesh or similar. Check to see if your linkages are aligned and not bent. Go from there.
What tranny is it?
Old Dec 1, 2005 | 10:59 AM
twenty's Avatar
Default Re: grinding (shamoo)
could it possibly be all fixed by just changing the fluid to a syncomesh or would it be a waste of time?
Old Dec 1, 2005 | 11:07 AM
shamoo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .bump! &raquo;</TD></TR><TR><TD CLASS="quote">could it possibly be all fixed by just changing the fluid to a syncomesh or would it be a waste of time? </TD></TR></TABLE>
Possibly, but I would do that first before worrying and spending money on rebuilding it, or replacing it. It's easy and it's a few dollars.
Old Dec 1, 2005 | 11:14 AM
95lstegman's Avatar
is it grinding in everyday driving (under 3500rpm) or up pretty high?
Old Dec 1, 2005 | 11:53 AM
twenty's Avatar
Default Re: grinding (95lstegman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95lstegman &raquo;</TD></TR><TR><TD CLASS="quote">is it grinding in everyday driving (under 3500rpm) or up pretty high?</TD></TR></TABLE>
i havent tested it out up high yet, but yeah i just bought the car and its a stock so im not out racing it lol. but im pretty sure it will be the same result up high or down low in rpms.
Old Dec 1, 2005 | 06:20 PM
95lstegman's Avatar
so does it grind between 1500 and 3500rpm?
LAOS
Aug 5, 2005 01:44 PM
trooper0641
18
May 6, 2005 06:50 PM
All-Motor H22A
Mar 2, 2004 02:35 PM
markv
Oct 25, 2003 03:40 PM
BrownGSR
Oct 13, 2003 02:01 PM
