Need help with my swap ASAP!!!
Old Nov 30, 2005 | 02:53 PM
crazyhtch's Avatar
Default Need help with my swap ASAP!!!
OK..i just did a swap into my 94 civic hb..i put a d16y7 swap..hooked everything up and went to turn it on and it startes but doesnt go over 2000 rpms..anybody no this problem??
Old Nov 30, 2005 | 02:55 PM
Luserkid's Avatar
Default Re: Need help with my swap ASAP!!! (crazyhtch)
Throttle body stuck open? Vac. leak? how high did it go?
Old Nov 30, 2005 | 02:59 PM
SuperSlow's Avatar
is your throttle cable tight enough?
Old Dec 1, 2005 | 02:37 AM
crazyhtch's Avatar
Default Re: Need help with my swap ASAP!!! (SuperSlow)
i dont think it any of that..throttle cables fine and so is the intake manifold..when u pin the gas pedal to the flow it just back fires alittle and doesnt go over 2000 rpms.. some1 said that my ecu my b in "safe mode"...or could it be the timing thanks
Old Dec 1, 2005 | 05:54 AM
For_Sale's Avatar
maybe wrong/busted ecu or maybe busted distributor?
Old Dec 2, 2005 | 07:28 PM
DB1_559's Avatar
u plugged the throttle sensors wrong switch it around happen to me
jdmsir96
Jan 7, 2008 04:59 PM
mario_pic
Jan 2, 2008 01:35 PM
c r x_s i
26
Apr 6, 2007 09:47 PM
TheThiefTheKnife'NTheGun
Nov 1, 2005 03:46 AM
Scean
Mar 31, 2004 06:23 PM
