shift linkage question
Old Nov 30, 2005 | 09:42 AM
b_serious's Avatar
Default shift linkage question
my shifter rattles when in 1st at a light ( when stopped clutch in) and when in 5th when driving..
its getting really anoying anyone have a cure for this? everything is tight.. i checked everything many times.. i think it might be hitting the exhaust? anyone know forsure?
98 ls motor in 98 ek coupe
Old Nov 30, 2005 | 09:47 AM
Kendall's Avatar
It would actually be more prone to hit the exhaust in 3rd and 4th gears but I wouldn't rule it out. Check the exhaust for marks and check the bolts and the bitch pin.
Old Dec 1, 2005 | 10:47 AM
b_serious's Avatar
Default Re: (Kendall)
well when i push it in 1st from N back and forth while the clutch is in at a light u can hear it hitting somthing and same with 5th.. i know its weird position for shifter to be to be hitting somthing.. and when i give it a little gas it moves the shifter and rattles
Old Dec 1, 2005 | 11:17 AM
IHateJDM's Avatar
Default Re: (b_serious)
look under your car and see what its rubbing, and make sure the rear linkage bolts are in well. If there isn't anything stuck up there, check your rear motor mount. If the rear mount breaks, the shifter will drop a little and hit the exhaust/heatshield (and you'll feel the shifter move as the motor torques forwards and back in the engine bay).
alvinoolivas
Jun 25, 2011 09:06 AM
jdmkris
Jan 14, 2010 03:08 PM
Hatchman98
Mar 20, 2007 03:42 PM
Hatchman98
Mar 20, 2007 10:51 AM
omg_miiiike
Jul 12, 2005 01:15 PM
