removing del sol window?
once the door panel is off, there is a plastic sheet that must be removed to gain access to the window. there are two bolts that hold the glass in place on the regulator, and the glass sits in a track. it will slide straight up and out of the door once the two bolts are removed. note - it must be rolled down the the proper height to gain access to the bolts. look for them. they are attached to the glass through a white clamp on either side of the window.
97reddelsol
Feb 15, 2012 09:25 AM
mikeycivics
Oct 4, 2011 09:13 AM
nfinitecc
Feb 24, 2005 02:17 PM
