Window Guides?? help my fix my del sol window
when i roll the window up or down it jerks the window out of the guide on the doorreally bad on the fender side arent there some kinda guides at the top of the door that keep it in line? i see too broken white clips up top on both sides but i didnt find them in the bottom of the door? does anyone have a diagram of the **** in the door? Thanks guys
Re: Window Guides?? help my fix my del sol window (nfinitecc)
I'm really not sure how to help ya, but if its the passenger side thats giving you problems, I have all the internals and the 2 windows off a passengerside door (94 Del Sol Si) and I would sell them cheap but you gotta pay shipping! PM me or email
(Reiketsukan2@aol.com)
Good luck!
Good luck!
Re: Window Guides?? help my fix my del sol window (Reiketsukan)
take off the door panel. i had the same problem. You'll see the track of the window, and then just put the key in and roll the window up and down and you should see where it is coming out from. mine was a simple little screw near the top left side of my door (driver side) that held in a rubber peice (if you take the door apart you'll see what im talking about). i wouldnt be suprised if its the same thing.
Re: Window Guides?? help my fix my del sol window (xxscaxx)
ive had the panel off, thats how i saw the clips, there are 2 screws on the top on the dooron opposite sides that go twoards the glass and the ends of the screws are touching the class which doesnt seem good, mybe there should be rubber stops on those, its coming out on the botton right, the bottom right corner of the glass swings out of the chanel as it goes down and it all come out of the tracks, but i dont know how it looked beofre so i cant tell whats supposed to be there. This is the drivers door BTW so use Bottom right ion that sense
ratchetEDsedan
10-19-2017 10:29 AM
Ju1cesk8er
06-18-2012 12:13 AM
97reddelsol
02-15-2012 09:25 AM
mikeycivics
10-04-2011 09:13 AM
Kod Sol
06-20-2011 07:54 AM
