I know this is a Honda Site, but I could use some help deciding? and some good opinions
Old Nov 29, 2005 | 05:23 PM
bigplansnocar's Avatar
Default I know this is a Honda Site, but I could use some help deciding? and some good opinions
This going to be long and confused, cause i am confused as to what to do?
Most everybody knows that i have been trying to design a Big single turbo Kit for my Z32 to support around 900-1000whp.
I have all the parts to do it, it is a matter of finishing fabing it all up and getting it all to work together.
Now the motor will handle the power and make the power i need, it is a matter of everything fitting, and if stuff does break, it won't be cheap to fix or replace.
Here is my dilema. As of yet i don't know if the kit and everything will fit.
Second if and when it does fit it is going to be cramped and not look that good.
Third, not only will i have to build custom exhaust manifold for the turbo, and Charge piping for everything else. I will also have to build a custom single intake manifold to allow Top Feed injectors cause i will need no smaller then 1000cc injectors and the biggest side feeds are 850cc.
Now my other dilema is I have a chance to try to swap in an SR20DET into my Z?
Now here are the pro's and cons of that.
Pro's
if i can get it to fit, There will be plenty of room for anything i want to do
Second, Parts are cheap and redily availble
third a lot easier to work on.
Con's
The oil pan sump is right where the Cross Member of the Z32 is. So either i will have to build a custom tubular Cross member to adapt it, or rework the oil pan, which is even harder.
With the SR, i can still make 700-800whp and in my Race class.
The 6 Cylinders have a minimum weight of 3500lbs, and the 4 Cylinders have a minimum weight of 2600lbs.
and an average proven weight to power at the track is for every 100lbs=10whp. That's dead weight, not rotating weight.
So a VG 6cylinder pushing 900whp runnin 9.6@150 should equal a
SR 4cylinder pushing around 800whp runnin around 9.6@150.
Also if you put the SR motor in, you will lose 300lbs on the front end alone which will allow for better weight transfer.
I just don't know which one to persue and finish.
if i had enough money i would build both to see what works and doesn't, But since i am shooting to get this done by Race season, i need to decide very soon.
Please off what i have told ya, let me hear some opinions?
thanks,
Danny
SR20DET in a Z
VG30DET with a custom Single Intake
Old Nov 29, 2005 | 05:36 PM
80884's Avatar
Default Re: I know this is a Honda Site, but I could use some help deciding? and some good opinions (ttzofut
How about a built RB26 and large single turbo?
My buddies car. http://www.z32power.com He's actually changing some stuff, might be going twin smaller turbo's, either way if your into Z's you probably know him already.
Yes, i know Joel, he is a great guy and giving me lots of advice.. We have talked for awhile now.
it is for NHRA SRWD class...
6 cylinder min weight, 3500lbs
4 cylinder min weight, 2600lbs.
Modified by ttzofutah at 3:09 AM 11/30/2005
Old Nov 29, 2005 | 05:40 PM
80884's Avatar
Default Re: (ttzofutah)
I'm not sure what class he plans on running but I think he want's it to be legal, that thing called a turbo isn't going to cut it right now, lol
Cool just wanted to make sure
Old Nov 29, 2005 | 09:48 PM
B20C5 Turbo's Avatar
New User
I know of some intellegent racers in your area that may be able to help you. PM for more details.
QuangAlang
Oct 30, 2007 10:50 AM
cL2.2
Sep 7, 2005 10:03 AM
tfalconier
Nov 17, 2003 10:47 AM
-Racer X-
Jan 15, 2003 03:20 PM
J2turbo21
Dec 25, 2002 07:44 AM
