weird alternator prob
Old Nov 29, 2005 | 04:01 PM
h22 civic's Avatar
Default weird alternator prob
ok what are the chances of a alternator going bad and causing odd check engine codes ?im getting 2 o2 sensor codes a electric load detectorand a vss code i changed the ELD figured it was that but no luck traced it to alt and found alt is not charging battery so im thinkig it is not giving the rite voltage to sensors and makeing them come up as faulty
Old Nov 29, 2005 | 04:11 PM
PLAN:B's Avatar
Default Re: weird alternator prob (h22 civic)
might sound funny, but did you check the alternator fuse?
i know on dc2's, if that fuse is blown, the speedo will not work and you will throw ELD. Always check the small stuff first and start eliminating pssible causes. If you haven't already checked the connections, do that (im sure you have though).
Old Nov 29, 2005 | 05:17 PM
h22 civic's Avatar
Default Re: weird alternator prob (PLANBmotorsports)
yeah i did that stuff the speedo actually bounces from 0mph to 100mph and the car is in park with no foot on the gas pedal lol,all the lites also surge oh yea this is in a 97 civic
HFpower
Oct 16, 2009 07:59 PM
pacifico
Sep 18, 2006 08:15 PM
rextec
Apr 8, 2006 11:33 AM
z1p
Nov 8, 2004 05:49 AM
