how much and how hard?
Old Nov 29, 2005 | 02:14 PM
XSIWANNAB's Avatar
Default how much and how hard?
Ok its a two part question.
About how much does a b16a cable run for?(used)
and is it hard to instal on a b18a?
Or shoul I just go for a b18a tranny, i would like the b-16 cuz it has shorter gears. now would it matter considering that the b16 is obdII and my b18a is a obdI
Old Nov 29, 2005 | 02:17 PM
Kendall's Avatar
Default Re: how much and how hard? (XSIWANNAB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XSIWANNAB &raquo;</TD></TR><TR><TD CLASS="quote">About how much does a b16a cable run for?(used)</TD></TR></TABLE>
What kind of cable?
Old Nov 29, 2005 | 02:18 PM
XSIWANNAB's Avatar
Default Re: how much and how hard? (Kendall)
just the whole tranny
bump
Modified by XSIWANNAB at 3:32 PM 11/29/2005
Old Nov 29, 2005 | 02:33 PM
loudassVTEC's Avatar
The b16 is OBD-2, and it has a cable trans??? I doubt it. What car are you putting it all in?? DA? If it's a DA, there is nothing different between the tranny installation of the LS trans. It's pretty much the same. Same axles, but here's what is different. If it's a 90-91 b16 trans, than it's going to need a 90-91 clutch disk. If it's 92-93, than you use the 92-93 clutch disk. The splines on the input shaft are slightly different. Other than the clutch disk, it'll go right into a DA with no mods.
Old Nov 29, 2005 | 02:40 PM
XSIWANNAB's Avatar
Default Re: how much and how hard? (loudassVTEC)
Nope its just going into b18a
so if its a obd1 or 2 it doesnt matter?, And about how much would it break me
Old Nov 29, 2005 | 05:04 PM
XSIWANNAB's Avatar
bump
travishoward
Transmission & Drivetrain
Oct 16, 2010 06:12 AM
allhonda
Jul 29, 2007 04:20 PM
Craigp23usa
Aug 23, 2006 07:26 PM
91-lsvtecsi
Aug 11, 2006 06:27 PM
dafunkdawg
Apr 28, 2002 03:17 AM
