stock bore size for d16z6 and d16y7
Does anyone know the stock bore size for these two engines.
I just bought a comtec headgasket that is 75.5mm and the place that I bought this from swears that it is for the stock bore of these two engines...
any info is appreciated.
tyia
tyia
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eyal 951 »</TD></TR><TR><TD CLASS="quote">it.s 75mm, 75.5 is .020 over for pistons. you either have to have your block machined, get piston and rings, or ditch the gasket.</TD></TR></TABLE>Yeah. and I don't think that you want to go through all that work just to keep from getting another head gasket.
-Red
-Red
It is weird that you can't get a Cometic Headgasket in 75mm... Go to the site. I says that the proper HG is 75.5mm.
What a sham.
http://www.cometic.com/catalogs/AutoCat04.pdf
What a sham.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.6t »</TD></TR><TR><TD CLASS="quote">It is weird that you can't get a Cometic Headgasket in 75mm... Go to the site. I says that the proper HG is 75.5mm.
What a sham.
http://www.cometic.com/catalogs/AutoCat04.pdf</TD></TR></TABLE>
Running that gasket on your "stock bore" block should not cause any problems. Call them and ask them.
What a sham.
