WILL 94 DELSOL STRUT/SPRING ASSEMBLEY FIT A 96 CIVIC HATCH??
Old Nov 29, 2005 | 01:07 PM
1slow4door's Avatar
Default WILL 94 DELSOL STRUT/SPRING ASSEMBLEY FIT A 96 CIVIC HATCH??
I know the 92-95 civic will fit as long as I use my stock 96 fork and lca. But will the delsol spring/strut (whole assembly) fit the same??????
Old Nov 29, 2005 | 01:30 PM
1slow4door's Avatar
anybody???help.................ttt................ ....
Old Nov 29, 2005 | 01:41 PM
ShadyBAB's Avatar
Default Re: (1slow4door)
They should fit, a lot of Del Sol parts are interchangable with 92-95 civic HB's. What year Del Sol are the struts off of?
Old Nov 29, 2005 | 02:55 PM
brusk13's Avatar
the front suspension setup is the same but the back is different. The LCA's on the back of the slow are the older style. Unless they changed it after 93 that I'm not aware of but my roommates 93 slo is different than my 96 hatch.
Old Nov 29, 2005 | 03:02 PM
Turbo_y8's Avatar
Default Re: (brusk13)
last time i checked civic/del sol's dont have struts but rather shocks
Old Nov 29, 2005 | 03:04 PM
whoDAT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brusk13 &raquo;</TD></TR><TR><TD CLASS="quote">the front suspension setup is the same but the back is different. The LCA's on the back of the slow are the older style. Unless they changed it after 93 that I'm not aware of but my roommates 93 slo is different than my 96 hatch.</TD></TR></TABLE>
correct, the rear lca's from the eg's are wider than the ek's rear shock fork.
i know because i modified ek tein flexes to my sol utilizing gsr rear lca's. you would have to grind down the lca bushing in order for it to work.
Old Nov 29, 2005 | 07:11 PM
1slow4door's Avatar
I see, But the front will fit?
Old Nov 29, 2005 | 08:02 PM
dwnthehatch's Avatar
The fronts fit, the rears require washers to fill the gap between the lca and the strut.
summerof2008
Mar 6, 2009 09:30 AM
keepinitrehaal
Suspension & Brakes
Mar 14, 2008 06:36 PM
SHITBOB
14
Jan 23, 2007 09:52 PM
chris_c
Nov 25, 2004 06:08 AM
blkeg2
Aug 26, 2004 10:11 PM
