need help timing belt d15
first off did you loosen the tensioner in the first place. if not you can do that put loosening the 14mm bolt which is located next to the waterpump. if you have that loosened i dont see why you cant get the belt on.
well if you put the t/b cover back on and the pulley, then you can acess it by taking out a rubber plug in the cover, loosen- turn over(manually by spinning pulley) 3 times to make sure all lines up then turn counter clockwise a little bit to tension other side of belt then tighten tensioner and put rubber plug back in
pmgriphone
19
Sep 4, 2015 08:11 PM
marymiller29456
Classic Hondas
Oct 31, 2012 12:03 PM
