Help did I Damage My Cap?
Old Nov 28, 2005 | 07:53 PM
shhh151's Avatar
Default Help did I Damage My Cap?
Ok here's the thing i got my system professionally installed and i just added a HO alternator so i removed my Cap out of my setup.
Not knowing that i had to discharge the Cap first i just cut the positive and the negative. I was just wondering did I damage my Cap?
I'm trying to put it into anoter car and its not working.
Any input is greatly appricated!!!
Thanks
Old Nov 28, 2005 | 07:56 PM
romoracing's Avatar
Default Re: Help did I Damage My Cap? (GSR515)
Discharge it then recharge it and see what happens.
Old Nov 28, 2005 | 08:00 PM
shhh151's Avatar
Default Re: Help did I Damage My Cap? (romoracing)
here's the thing before i cut the wire i took the my fuse out of my distribution block... will that discharge my cap?
Old Nov 28, 2005 | 08:03 PM
nsxxtreme's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR515 &raquo;</TD></TR><TR><TD CLASS="quote">here's the thing before i cut the wire i took the my fuse out of my distributer... will that discharge my cap?</TD></TR></TABLE>
Lol your distributor is what provides spark to your car.
Is it one of those caps with the stupid electronics on top?
Normally no you cannot damage a cap that way. But you may have damaged the un-needed electronics if the wires crossed.
Old Nov 28, 2005 | 08:07 PM
shhh151's Avatar
Default Re: Help did I Damage My Cap? (nsxxtreme)
oh oops i meant distribution block
Old Nov 28, 2005 | 08:10 PM
shhh151's Avatar
here is my cap
Old Nov 28, 2005 | 08:19 PM
nsxxtreme's Avatar
Lets see the top where the wires go.
If the contacts go straight through then maybe you just killed the electronics. The cap will still work you just wont have the digital readout. The digital display is just there for eye candy.
Is there a remote wire on that.
Old Nov 28, 2005 | 08:27 PM
shhh151's Avatar
this is the new version of the one that i have
http://www.cardomain.com/item/STISC201MNC
Old Nov 28, 2005 | 08:35 PM
nsxxtreme's Avatar
Your fine just hook it up it will still work. Even if the display doesn't the cap will.
Old Nov 28, 2005 | 08:46 PM
shhh151's Avatar
i don't get how my digital read out just dosn't work anymore
Old Nov 28, 2005 | 09:19 PM
romoracing's Avatar
well some dont kick in right away. i had one that only work at really high bass levels.
Old Nov 29, 2005 | 09:31 AM
shhh151's Avatar
ok i did some reasearch and found out that my cap does not need to be charged or discharged it does it automatically
Old Nov 29, 2005 | 03:38 PM
shhh151's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxxtreme &raquo;</TD></TR><TR><TD CLASS="quote">Your fine just hook it up it will still work. Even if the display doesn't the cap will.</TD></TR></TABLE>
well my cap doesn't seem to be working at all
averyvm
May 8, 2009 11:37 PM
eK9aT10pSi
Oct 1, 2005 08:27 AM
R Thizzel
Audio / Security / Video
17
Nov 22, 2004 05:48 PM
t25hatch
Oct 20, 2004 11:10 AM
junglistgsr
Dec 3, 2001 08:19 PM
