Solid motor mounts
Old Nov 28, 2005 | 06:45 PM
zx2gotboost's Avatar
Default Solid motor mounts
Is there a "Home mechanic " way of making SOLID motor mounts?
I have Energy suspention mounts and I plan on having some power here shortly, figured Solid motor mounts would be the best for the power I plan on making!
Old Nov 28, 2005 | 07:19 PM
LastRide2's Avatar
Default Re: Solid motor mounts (zx2gotboost)
hasport motor mounts... you get what you pay for
Old Nov 28, 2005 | 07:31 PM
aalb1's Avatar
What you can do is clean your stock motor mounts real well and then use some caulk in them with the MM inserts. They will stiffen them up a little bit.
Also which mounts do you have? The sports one or the race ones? If you get the race ones they are a bit stiffer.
Old Nov 28, 2005 | 08:24 PM
binomialPDF's Avatar
New User
Old Nov 28, 2005 | 09:45 PM
Default Re: Solid motor mounts (aalb1)
Actually, I have the inserts, not a full mount, you slide the polyureathane insert in ur stock mount....... There RED. Thank you!
Old Nov 28, 2005 | 10:33 PM
ROK801's Avatar
https://honda-tech.com/zerothread?id=1000151
scroll down a little bit and there is a DIY on it.
alx_90ef
20
May 30, 2014 06:31 AM
NAmodified
Oct 16, 2007 08:35 AM
Rod.
Jul 2, 2005 11:49 PM
Bbasso
Mar 4, 2005 05:48 PM
6GACCORDH22
Sep 11, 2002 06:01 AM
