Dead Battery Problem!!!
I have a 89 prelude and just yesterday I went out to start my car and the battery was dead. I took out the alternator and had it tested only to show that it was just fine. I also tested the battery and it was fine also. any ideas? what could cause this?
Thanks, smash
Thanks, smash
did the engine turn over at all? and the first thing you should always do is check your fuse...i learned that the hard way. And if the engine isn't turning over it could be your starter.
Try a different battery. I had the same thing happen to me before. I had a battery tested, and it tested out fine, but after running it in my car awhile, turn my car off, then try starting it again, it wouldn't start. I just got a different battery, and it worked just fine. Started up every time
W O T
May 8, 2007 10:36 AM
smash fascism
Nov 29, 2005 11:57 AM
