Budget B16 swap in 88 crx si
Old Nov 28, 2005 | 04:06 PM
88 Rex Si's Avatar
Default Budget B16 swap in 88 crx si
Okay, I have a 1988 Honda Crx Si, and i plan to do the b16 swap. What i have to start with......B16a Bottom end with a bad piston. I'm still in need of A head,90-93 integra axles, B-series crx mounts,alternator and alternator bracket, Tranny, intake mani and exhaust mani, shiftlinkages, starter, flywheel and clutch, crank pulley.... I can get some of that stuff for kinda cheap...Im new to honda-tech cuase i just came from drag va and ive been searching for an hour about b16 swap help but no luck
My question is:
Do i absolutely have to buy after-market shift linkages? or is there any shift linkages i can use that i can find for cheap? and does anyone have some of the stuff i need?
Thanks in advance for your help
Old Nov 28, 2005 | 05:36 PM
31flavorscivic's Avatar
Default Re: Budget B16 swap in 88 crx si (88 Rex Si)
you can cut and weld the integra shift linkage to fit I believe.
Old Nov 28, 2005 | 05:43 PM
T3k C's Avatar
Default Re: Budget B16 swap in 88 crx si (31flavorscivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 31flavorscivic &raquo;</TD></TR><TR><TD CLASS="quote">you can cut and weld the integra shift linkage to fit I believe.</TD></TR></TABLE>
Definitly!
Old Nov 28, 2005 | 05:45 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: Budget B16 swap in 88 crx si (B16DSEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16DSEF &raquo;</TD></TR><TR><TD CLASS="quote">
Definitly!</TD></TR></TABLE>+2
I did that with friends swap worked like a charm
Old Nov 28, 2005 | 05:51 PM
88 Rex Si's Avatar
Default Re: Budget B16 swap in 88 crx si (Ace$nyper)
how much would some one charge me to do that?
Old Nov 28, 2005 | 07:51 PM
ExodusJKD's Avatar
Just spend the money and get Hasport mounts and linkage.
Old Nov 28, 2005 | 09:03 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 Rex Si &raquo;</TD></TR><TR><TD CLASS="quote">how much would some one charge me to do that?</TD></TR></TABLE>
If I was doing that for someone I wouldn't charge more than like $15, because it doesn't look that hard. I also believe that payment could be in beer it is so simple.
Old Nov 28, 2005 | 10:40 PM
drag-ek's Avatar
You can shorten your stock one.
Old Nov 29, 2005 | 12:36 PM
88 Rex Si's Avatar
Default Re: Budget B16 swap in 88 crx si (drag-ek)
thanks for everyones help......i got mounts and im getting linkages
playswcars
Feb 15, 2019 05:33 PM
street_freaks
Sep 25, 2006 07:23 PM
MulletManRockStar
Nov 6, 2004 04:07 PM
thecorey
Sep 26, 2002 02:13 PM
bubblebackinSI
Jan 2, 2002 07:10 AM
