Anyone have Instructions on Camshaft Changing?
Old Nov 28, 2005 | 03:47 PM
SrT4u2nV's Avatar
Default Anyone have Instructions on Camshaft Changing?
i searched and found one link but its not to helpful.
Old Nov 28, 2005 | 04:33 PM
Saiyansniper's Avatar
Shop Manual/Haynes Manual FTW
Its actually pretty easy to swap cams, hardest part would probably be resetting the timing after you pull the timing belt off.
Old Nov 30, 2005 | 08:20 AM
SrT4u2nV's Avatar
ohhok well im just lookin for some pics and some helpful hints if anyone has any more of them
Old Nov 30, 2005 | 08:21 AM
98vtec's Avatar
moderator emeritus
Default Re: (SrT4u2nV)
download the helms manual
Old Nov 30, 2005 | 02:04 PM
The_Sober's Avatar
Default Re: (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Saiyansniper &raquo;</TD></TR><TR><TD CLASS="quote">Shop Manual/Haynes Manual FTW
Its actually pretty easy to swap cams, hardest part would probably be resetting the timing after you pull the timing belt off.</TD></TR></TABLE>
yup...
Old Nov 30, 2005 | 02:15 PM
98TypeSH's Avatar
Default Re: (The_Sober)
get new cam seals and some hondabond.
in short and not very detailed: yank the valvecover, remove upper timing cover and lock tensioner service bolt, slide the belt off the cams, loosen the cam caps from inside out. remove cams, remove cam gears, replace cam seals, reinstall. etc.. etc..
timing on any H series motor ( specifically with an auto tensioner) sucks ***. get a helms for sure.
Old Dec 1, 2005 | 12:53 AM
SrT4u2nV's Avatar
What about Changing the Springs and Retainers? And afterwards should i do a valve lash check? and how would i come about doing all this? Lastly how do i get TDC? do i just keep turning the crank till all timing marks line up?
Old Dec 2, 2005 | 01:05 AM
SrT4u2nV's Avatar
*buMp*
Old Dec 2, 2005 | 04:51 AM
PirateMcFred's Avatar
http://www.helminc.com get the service manual for your car. It is over 1000 pages of everything you need to know. tiwill be some of the best money spent on your car. Haynes sucks, Chiltons is better but both still suck in comaprison to the Helm.
Pirate
Old Dec 3, 2005 | 03:15 PM
SrT4u2nV's Avatar
well to late to find that book so i guess i just need some luck
Old Dec 3, 2005 | 05:00 PM
InvaderTrax's Avatar
Where can I buy the Helm manual? Advance? Autozone? Pepboys? I could use one for tomorrow
Old Dec 3, 2005 | 07:28 PM
petern101's Avatar
Default Re: (InvaderTrax)
google is your friend
anyways
http://www.helminc.com/helm/ho...S7WV7
joanie
May 27, 2014 06:20 AM
Powered by VTEC
Jan 23, 2008 07:17 AM
GSR-T-
Honda Motorcycles
Sep 5, 2006 07:22 AM
casmello
Jan 3, 2006 06:52 PM
RacerZook
Jan 6, 2004 04:52 PM
